I’m trying to set up an automation to send out a message any time there is a state change to an entity, but it doesn’t seem to work. This syntax passes the configuration checker, but never seems to be triggered. My Telegram integration works with an automation that sends a message when HA starts and stops, so I believe that the integration is at least fine.
Does anyone have any suggestions?
- alias: Device Status Detection
hide_entity: false
- platform: state
entity_id:
- zha.king_of_fans_inc_hdc52eastwindfan
- zha.ledvance_br30_rgbw
- zha.ledvance_br30_rgbw_2
- zha.ledvance_br30_rgbw_3
- zha.ledvance_br30_rgbw_4
- zha.lumi_lumi_sensor_wleak_aq1_2
- zha.lumi_lumi_vibration_aq1
- zha.lumi_lumi_weather
- zha.lumi_lumi_weather_2
- zha.lumi_lumi_weather_3
- zha.osram_lightify_gardenspot_rgb
- zha.osram_lightify_par38_on_off_dim
- zha.osram_lightify_par38_on_off_dim_2
- zha.philips_lct016
- zha.philips_lct016_2
- zha.sengled_z01_a19nae26
- zha.zha_waxman_leaksmart_water_sensor_v2_00128dd1
- data:
message: "{{ trigger.to_state.attributes.friendly_name }} changed state."
title: '*Home Assistant*'
service: notify.notify_telegram
