Automation to set config parameters
I’ve been searching for this and have yet to figure it out. I understand I can set config parameters in HA. What I haven’t figured out is how to template a list of entity id’s based on a zwave model so I can write the automation once and than bulk update config parameters without have to manually search entity id’s etc.
ie. I want to grab all the HS-WD100+ in HA, loop through them and set the config parameters without having to list the entity_id’s manually.
Here’s a pure template service call that I think does what you want.
service: zwave_js.set_config_parameter
  parameter: 4
  value: 'No'
  device_id: >
    {% set ns = namespace(devices=[]) %}
    {% for id in integration_entities("zwave_js") %}
    {% if device_attr(id, "model") == "14294 / ZW3005" %}
    {% set ns.devices = ns.devices + [device_id(id)] %}
    {% endif %}
    {% endfor %}
    {{ ns.devices | unique | list }}
It loops through all of the entities for the Z-Wave JS integration and for each entity, queries the entity’s device model, and if it’s the desired model name ("14294 / ZW3005" in the example) adds the entity’s device ID to a list of device IDs. At the end, it reduces the list to the unique set of device IDs. That set is then the target of the service call.
Another non-template approach would be to just create a group consisting of one entity from each desired device, and just pass the group entity ID to the service call instead.
That’s amazing! Going to check this out. Thanks so much for the help.
Was looking for a solution to simplify an automation where I update a ZWave parameter for a large number of devices and this worked PERFECTLY. Wanted to say THANK YOU to freshcoat for this snippet of code that made things a ton easier as I migrated some automations from HomeSeer to HomeAssistant!
Wanted to share what I ended up with which loops over devices instead of doing it by param:
alias: HS-WD100+
sequence:
  - repeat:
      for_each: >
        {% set ns = namespace(devices=[]) %} {% for id in
        integration_entities("zwave_js") %} {% if device_attr(id, "model") ==
        "HS-WD100+" %} {% set ns.devices = ns.devices + [device_id(id)] %} {%
        endif %} {% endfor %} {{ ns.devices | unique | list }}
      sequence:
        - service: zwave_js.set_config_parameter
            parameter: "7"
            value: "1"
            device_id: "{{ repeat.item }}"
            parameter: "8"
            value: "1"
            parameter: "9"
            value: "1"
            parameter: "10"
            value: "1"
mode: single
