Automation to set them for 1 dashboard
I’ve been getting frustrated with my google search results on this one I finally broke down and decided to try here.
How do I change the theme for a single dashboard in an automation or script?
Realized I might not be explaining it correctly, so here’s a screenshot. I want to set one of these options with an automation for this dashboard only.
Screenshot
Just wanted to give this a gentle ‘bump’.
Is this what you want?
frontend.set_theme
No. I’ve seen this, but I want 1 dashboard to have a theme regardless of this setting. This setting doesn’t let you pick which dashboard to apply this to.
EDIT: Also, this doesn’t let you pick a theme other than Dark or Light.
The Theme field allow you to pick a theme by name.
To my knowledge, that’s not possible manually, let alone via a service call. How are you doing this manually now? (Sorry, tweaking the UI isn’t my field of expertise)
Yep. My bad. I was moving too fast. That’s absolutely correct, but still not quite what I want. :slight_smile:
I edit the view from the dashboard. I can set a theme there. I updated my original post with a screenshot.
Correct me if I’m wrong but the screenshot you posted shows how to change the theme of a dashboard’s tab page. Each tab page, in a given dashboard, can have a different theme.
So you want a service call to do the same thing? (I don’t see any frontend service call able to do that)
Exactly. So, I’m pretty much out of luck then? It’s all or none?
I guess I could settle for this, but isn’t this system wide and would effect all my dashboards on all my devices?
