Automation to stop a fan after variable time
Have been trying some different solutions from the forum that i couldn’t get to work and have now tried to do my own solution but got a bit stuck.
I want to turn on a fan. The fan must turn off after the time that i set on a slider.
My first post so i hope the code formatting i correct
Edited: Edited the code input, removed spaces between lines and used ``` befor and after code.
input_number:
  toiletfan_input:
    min: 0
    max: 120
    step: 30
    step: 1
timer:
  fan_timer:
    duration: '00:01:00'
script:
  start_fantimer:
    sequence:
      - service: timer.start
        data_template:
          entity_id: fan_timer
          duration: "00:{{ states('input_number.toiletfan_input') }}:00"
automation:
  - alias: 'Toilet fan control'
      - platform: state
        entity_id: fan.toilet_fan
        to: 'on'
    condition:
      condition: template
      value_template: "{{  timer.fan_timer  < 1 }}"
      - service: fan.turn_off
No, I think you must not have used the </> button to format the code.
I think you are nearly there, the input_number looks okay (but the numbers a bit wild, asuume minutes and go for 1 to 20 but it’s your toilet, step of 30 though ??? ). The automation is a bit off.
There are many ways to do this but the simplest is : -
automation:
      - platform: state
        to: 'on'
      - delay: "00:{{ states('input_number.toiletfan_input') | int }}:00"
Do you really have a fan domain ? I just have switches :man_shrugging:
Looking at this I have no idea why I cast the number to int, but I always have
I usually have the fan come on with the light, and go off 10 mins after the light goes out
I was just helping a chap with a similar auto on discord. This should be in the docs more explicitly.
Maybe the fan timer value is a string?
I would do this with a script, similar to what petro wrote here. The problem with the delay is when the fan get’s turned on again during the delay. This may never be the case for OP, but for other similar automations. Just my 2 cents xD
No I agree, and my light/fan timers use scripts too but I’m pitching this at his level.
Let him get comfortable with that and then we’ll address bypassing timer issues
Trug I’m not using a timer here, I’m using a delay
And yes HA stores input numbers as strings.
My point here was that I was just going to use it in a string anyway, so why bother with the int ??? (that’s a rhetorical question BTW)
I did it this way I hope it helps
#scripts.yaml
ventilador:
   sequence:
      data_template:
        entity_id: timer.ventilador
        duration: '00:{{ states.input_number.timer_minutes3.state | int }}'
#configuration.yaml
timer:
    ventilador:
input_number:
  timer_minutes:
    initial: 0
    max: 180
    min: 0
    step: 1
#automations.yaml
  - data:
      entity_id: switch.ht
    service: switch.turn_off
- id: '1568856065189'
  alias: Timer ventilador
  - event_data:
    event_type: timer.finished
    platform: event
  condition: []
  - data:
      entity_id: switch.ventilador
Kobainer, you wouldn’t be a Nirvana fan would you ?
The nickname is more related to my last name, but who diden’t enjoy his music? :slight_smile:
So thanks for the help.
I tried with a delay earlier but didn’t work for me so dont know where i went wrong. It works with the delay now so thanks for that.
Now i will be looking at trying the scipt that pedro made here (thanks @Burningstone)
As to the Domain. Yes i have a fan domain… the domain has a lot of fancy fan funktions. But in reality im just talking to a switch so i might change this.
Regarding the stepsize @Mutt. Yes these were just choosen a bit random. But they will be relatively high until i get my humidity sensor connected. Thnaks for the help :slight_smile:
Don’t try to run before you can walk, get this working and we’ll enhance it.
The point is the format and the way it is constructed, this happens to that, then we call a delay, then we act on this to turn it off. Its not a formula, or a construct from another piece of software, it’s a logical sequence.
petro :wink:
Kobainer, did you get it working.?
Have you discovered the issues with it ?
Do you want to adapt/extend it.?
If you post your current code (make sure it looks like mine ie the format) we can work from that point.
It worked really nicely with the delay. Don’t know where i made the mistake first time i tried the delay.
Tonight i’ll look into scenes to expand it. I’ll make a post later when i worked a bit on it myself first… either to ask for help or share how i expanded @Mutt :slight_smile:
Tomorrow my ZigBee hub and humidity sensors arrive. Then i’ll start implementing them aswell.
Tinkering with all this is so much fun, to bad i have to wait for the family to sleep :stuck_out_tongue:
I have a near identical code for my fan, as Mutt had posted, so I’m not going to pin it here. But as far as the reason why your code didn’t work. When I was playing with input sliders I had noticed that I had to cast values to integer with the |int operand otherwise they are coming as floats and the delay will not work. You can test this in the Developer Tools > Template.
This is then particularly relevant when you concatenate values as in 00:{{ states('input_number.toiletfan_input') | int }}:00.
Hope it helps.
So i changed it to use script after petros principle. Works awesome :slight_smile: here the code
input_number:
  toiletfan_input:
    min: 0
    max: 60
    step: 10
automation:
  - platform: state
    to: 'on'
  condition: []
  - service: script.turn_off
    entity_id: script.start_fantimer
  - service: fan.turn_on
  - service: script.start_fantimer
script:
  start_fantimer:
    sequence:
    - data:
