Hi all,
I bought a used Zibee Xfinity Keypad/PIN Pad and wanted to use it with Alarmo. I found a few solutions when you are using Zigbee2MQTT but I use ZHA, so I wrote an automation that would sync the Keypad and Alarmo using Alarmo built-in MQTT capabilities.
Pre-requisites:
- Alarmo Custom Integrations installed and configured:
- MQTT Enabled and configured to require a code
- Armed away, Armed home, and Armed night Modes configured
- A Pincode configured
- Mosquito broker installed and configured
- An Zigbee Xfinity XHK1-UE (I bought a second hand one at eBay) configured in ZHA
- In ZHA configuration, set the Master code for the alarm control painel to
00000and the number of consecutive failed code entries to trigger an alarm to1000(the automation is not using this feature)
- An correctly configured notify service
What the blueprint and automation does:
- Enable you to use the Keypad to Arm and Disarm Alarmo using the codes configured in Alarmo
- Enable Alarmo to sync its state with the Keypad
- Send notifications when the Alarm is Armed, Disarmed or is Arming, and when an invalid password is used or the Alarm failed to arm because a sensor was triggered.
OUTDATED - You can still use the automation, but now I have created a blueprint to make it easier to use.
The automation:
IMPORTANT: Replace <replace me for your Keypad ieee>, <replace me for your Keypad device_id> for your device IEEE and device_id, and set the keypad Master code for the alarm control painel to 00000
alias: "Alarmo - ZHA Xfinity Keypad and Alarmo Syncronization "
description: >-
This automation will integrate a Xfinity xhk1-ue ZigBee Wireless Keypad from
Comcast with Alarmo HACS addon. It allows you to arm and disarms Alarmo via the
keypad using the Alarmo passwords and not the Keypad password configured in
ZHA. It will also sync the keypad state with Alarmo.
- platform: event
event_type: zha_event
event_data:
device_ieee: <replace me for your Keypad ieee>
args:
arm_mode_description: Disarm
- platform: event
event_data:
args:
arm_mode_description: Arm_Day_Home_Only
- platform: event
event_data:
args:
arm_mode_description: Arm_All_Zones
- platform: event
event_data:
args:
arm_mode_description: Arm_Night_Sleep_Only
- platform: mqtt
topic: alarmo/state
payload: disarmed
- platform: mqtt
topic: alarmo/state
payload: armed_home
- platform: mqtt
topic: alarmo/state
payload: armed_away
- platform: mqtt
topic: alarmo/state
payload: armed_night
- platform: mqtt
topic: alarmo/state
payload: arming
- platform: mqtt
topic: alarmo/event
payload: INVALID_CODE_PROVIDED
value_template: "{{ value_json.event }}"
- platform: mqtt
topic: alarmo/event
payload: FAILED_TO_ARM
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: mqtt.publish
topic: alarmo/command
payload_template: >-
{ "command": "DISARM", "code": "{{ trigger.event.data.args.code
- conditions:
sequence:
{ "command": "ARM_HOME", "code": "{{
trigger.event.data.args.code }}" }
- conditions:
sequence:
{ "command": "ARM_AWAY", "code": "{{
- conditions:
sequence:
{ "command": "ARM_NIGHT", "code": "{{
default: []
- choose:
- conditions:
- condition: not
conditions:
- condition: device
device_id: <replace me for your Keypad device_id>
domain: alarm_control_panel
entity_id: alarm_control_panel.front_door_alarm_pinpad_alarmcontrolpanel
type: is_disarmed
sequence:
- device_id: <replace me for your Keypad device_id>
type: disarm
code: "00000"
- service: notify.notify
message: clear_notification
tag: alarmo
title: Alarmo
message: Home alarm Disarmed.
tag: alarmo
- conditions:
sequence:
type: arm_home
code: "00000"
tag: alarmo
title: Alarmo
message: Home alarm Armed Home.
tag: alarmo
- conditions:
sequence:
type: arm_away
code: "00000"
tag: alarmo
title: Alarmo
message: Home alarm Armed Away.
tag: alarmo
- conditions:
sequence:
type: arm_night
code: "00000"
tag: alarmo
title: Alarmo
message: Home alarm Armed Night.
tag: alarmo
- conditions:
sequence:
title: Alarmo
message: Home alarm is arming.
tag: alarmo
- conditions:
sequence:
title: Alarmo
message: An invalid code was used to arm or disarm the Home Alarm.
tag: alarmo
- conditions:
sequence:
title: Alarmo
message: >-
Home Alarm failed to arm because of the following sensors: {%
for open_sensor in trigger.payload_json.sensors %}
{{ open_sensor.name }}
{% endfor %}
tag: alarmo
default: []
mode: parallel
max: 2
