I’m fairly new to Home Assistant, but slowly moving over from a hodgepodge of Smartthings, Hubitat and diy ESP based wifi devices.
So I’ve got a switch that turns a bathroom light on/off, no problem, this just happens. Problem is, kids and wife doesn’t seem to understand turning the light off when not occupying the bathroom is a good idea. Ok, quick and easy solution, time the light to go off after 10 minutes. It works, but it’s not ideal when you’re in there for longer periods of time.
Installed a contact sensor on the door, figuring i could still keep the timed aspect but add in an override where the automation wouldn’t fire unless the door had closed and opened again. Well, I’m not getting it to work.
Tried a bunch of ways, but I can only seemingly get it to turn off either by time or sensor. Even tried setting a bool DoorHasOpened but I’m not getting it to trigger properly.
It’s a common challenge for sure. I have never perfected a solution either but i can offer a couple of pointers that will likely help.
The door sensor is not so good for triggering an switch ‘off’ condition. A door opening/closing in quick succession would happen when someone enters or leaves.
You really need some kind of presence detection in the bathroom. To detect when someone is still in the room. Something like a motion sensor.
In the case of using a motion sensor you can then base the time to turn off the switch on when motion is no longer detected for a period of time.
Cheers
To do exactly what the title of your post describes, you just need to have a trigger of the state of DeviceB and an action sequence of a delay followed by a service call to turn off Device A.
For example - this turns off the lights 10 minutes after the door opens/closes and if the door changes state while the 10-minute timer is running, it resets the timer to 10 minutes.
alias: Turn off light 10min after door change
mode: restart
- platform: state
entity_id: binary_sensor.bathroom_door
condition: []
- delay:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
- service: light.turn_off
entity_id: light.bathroom
However, I think you may find this implementation annoying for the reason you mention - the light turning off when you don’t want it to. For example, it’ll turn off if you take longer than a 10 minute shower.
I find the door-sensor-only automation (light on when door opens, off when door closes) works really well for closets, and it has the side-benefit of encouraging folks to close doors when they’re done, too. I’m not a fan of it for rooms, though.
For bathrooms, I use a combination of a motion sensor and a door sesnsor. The motion sensor always turns on the lights when it detects motion. After motion is no longer detected for X minutes, the lights turn off, but only if the door is open. If the door is closed when the “no motion” is detected, then the automation will wait for the door to open before turning off the lights. I’ve lived in a home with multiple other people with that type of automation for the better part of a year now, and my verdict is that it works well.
Thanks, yes, this is pretty much how I have it at the moment, when the door changes state the timer is reset, and that works fine apart from when I want to escape the world (kids) and lock myself in for 15 minutes
The idea was that in addition to the switch use the contact sensor to, pause if you will, the automation if the door hasn’t closed and then opened again during the N minutes. As in, if the door closes the automation waits for it to open again before turning the light off. This is what I’m really struggling with I guess.
Basically I want it to turn off the light after N minutes UNLESS door closes, then wait for door to open and turn off instantly.
This should cover instances where someone turns the light on to get a towel or whatever and don’t close the door as well as normal use and those other cases where it just takes longer.
Yes, I get it, should use a motion sensor, I’ve got no spares at the moment and the one I did have in there died from humidity, just trying to think outside the box
If you do ever go the motion sensor route, I have had good experience with the Philips Hue motion sensors - I have several mounted high in bathrooms (where humidity gets high), and they work great. The batteries last multiple years, and I haven’t had one fail in over 3 years. Not a super-long time, but promising so far.
Regarding the automation if all you have is a light switch and a door sensor, though…
Having the light switch in addition to the door sensor does give you additional options. I suggest you think through how you want the lights to behave. Draw out a state machine diagram if that helps - I use those in planning my more complicated automations.
One strategy I’ve found for simplifying automations (both writing and debugging) is to separate out detection logic and action logic. For example, in the bathroom, I have an input_boolean defined to indicate whether the bathroom is occupied or not. I have a separate automation that sets/clears this input_boolean. I then have another automation that triggers on the input_boolean and decides what to do when the bathroom is occupied or vacant. This makes it much easier to debug, and you get the side-benefit of recorded data about when the bathroom was occupied via the history of the input_boolean.
For reference, here’s roughly what I use for my bathroom occupancy detection logic in an automation blueprint. Since you’re not using a motion sensor, you could probably use the light switch in its place for the “turn on” logic.
- platform: state
id: 'Motion Detected'
entity_id: !input motion_entity
to: 'on'
- platform: state
to: 'off'
for:
seconds: !input no_motion_timeout
value_template: >
{{ door_entity != none and is_state(door_entity, 'on') }}
condition: []
- alias: Determine if motion was detected
choose:
- alias: Choice 0 - Motion detected
conditions:
- condition: trigger
sequence:
target: !input target_boolean
- alias: Choice 1 - Motion cleared and door open/unspecified
conditions:
- condition: state
state: 'off'
for:
- alias: Door sensor is unspecified or OPEN
condition: or
conditions:
- '{{ door_entity_1 == none }}'
- '{{ is_state(door_entity, "on") }}'
sequence:
- service: input_boolean.turn_off
- alias: Choice 2 - Door opened
conditions:
condition: or
conditions:
- '{{ door_entity == none }}'
sequence:
- alias: Wait a bit to see if someone entered the room
delay: 00:00:03
- choose:
- alias: Make sure there is still no motion
conditions:
- condition: state
state: 'off'
sequence:
default: []
From there, I have a separate automation that decides what to do when the bathroom occupancy changes. For yours, it should be pretty simple - trigger on the input_boolean going to off and call the light.turn_off service.
