Automation to use Sonos speaker as alarm - never triggers except manually
I am trying to use the HA Automations to create an Alarm every morning that plays a radiostationt through my Sonos One (w/Alexa) speaker.
When I manually trigger it, it works as expected. However, it never triggers itself based on the Time (05:45) that i’ve set the automation to run at.
Pulling my hair out! Any advise is super appreciated.
YAML
alias: 05:45am Wake Up Alarm
description: ""
triggers:
  - trigger: time
    at: "05:45:00"
    enabled: true
conditions:
  - condition: not
    conditions:
      - condition: device
        device_id: 4663682a12c8529ef23c023135388526
        domain: alarm_control_panel
        entity_id: 32a0a2fcb72de52e896413e65d7170e4
        type: is_armed_away
actions:
  - action: media_player.volume_mute
      is_volume_muted: false
      entity_id: media_player.bedroom_sonos
  - action: media_player.volume_set
      volume_level: 0.05
  - action: music_assistant.play_media
      media_id: NTS Radio 1
    metadata: {}
  - action: light.turn_on
      entity_id: light.bedroom_main_light
      brightness_pct: 0
  - repeat:
      sequence:
            volume_level: "{{ (0.05 + (repeat.index * 0.025)) | round(2) }}"
            brightness_pct: "{{ (repeat.index * 6.25) | round(0) }}"
        - delay: "00:00:10"
      count: 8
mode: single
What does the trace show? I suspect one of your conditions is causing it to fail. Conditions are not checked if you run the automation manually.
Could you explain what you mean by trace please?
You can use template triggers for this. For instance, this triggers a light based on a certain alarm id:
description: ""
triggers:
  - value_template: |
      {% set entity = 'switch.sonos_alarm_123' %} {{
        state_attr(entity, 'scheduled_today')
        and now().replace(microsecond=0) == today_at(state_attr(entity, 'time'))
    trigger: template
conditions: []
actions:
  - data:
      brightness_pct: 100
      transition: 600
      device_id: 123
mode: single
