Automation to write attribute to an input_number
Each end of the month I write a value to input_number.electriciteit_verbruik_januari, input_number.electriciteit_verbruik_februari etc
Is it possible to attach an attribute “date” ( like “1 januari”) to it ? So I can make a chart out of it ?
this is what I have now…
service: input_number.set_value
  entity_id: >-
    input_number.electriciteit_verbruik_{{
    now()|as_timestamp|timestamp_custom('%B')|replace('y','i')|replace('rch','art')|replace('ai','ei')|replace('ne','ni')|replace('st','stus')|replace('Oc','ok')|lower
  value: "{{ states(\"sensor.import_stroom_maand\") | float }}"
i don’t believe you can add on your arbitrary values. that said, the system does track the dates of change… not good for 1/month writes…
i must admit, it’s a little strange to use an input_number to do that. if you want to track that so that you can do processing and such on it, you might consider writing it out to a csv or json file using: File - Home Assistant
