Automation Traces not displaying
For some reason I can’t get the automation traces to show up in the GUI. These are automations of which I’ve been able to view traces for previously. They have unique ID’s set. The panel below the trace selector is completely blank. It’s the same case for all my automations so guessing it’s some kind of frontend issue… (cache clear does nothing to fix it)
Any ideas?
Tried again today and the traces show up… no idea why there was an issue so leaving this open incase others have some input.
Do traces get cleared after a restart?
:man_shrugging:
I do not see traces for any of my automations…
Do your automations have an id: ?
yes they do. But my statement is not entirely correct. Some of them do have traces, but others which definitely ran within the last 24h do not…
same problem here, all traces are gone after restart.
are there any settings to save traces even after restart?
No there isn’t. The traces get reset during a restart.
still, this is not very clear, and I dont see any traces at all.
What I dont get either, is that above is mentioned the traces get reset at startup, but there is rather large saved_traces file in the .storage. Maybe that has changed in the last half year.
issue: No Traces Found on any automation, scripts show fine · Issue #12025 · home-assistant/frontend · GitHub
edit
just found the id: needs to be a slugified alias really. no spaces, (and no special characters), not sure about the leading capital, but to be sure, this makes work:
instead of:
  - alias: This is an automation
    id: This is an automation
we need:
