Automation trigger based on time remaining of a helper timer
I created a helper timer that is easily set, paused, and otherwise manipulated via service calls. Works great!
I want to trigger other events/automations based on the amount of time remaining while the timer runs. For example, change the light color when there’s 5 minutes left on a 30-minute timer. Can’t figure out how to trigger these. The only options available in the UI are Duration and Restore.
I couldn’t find much info in the documentation, and I’m happy to use yaml if needed. Tried this without success:
platform: state
entity_id:
  - timer.kids_bath_fan_timer
attribute: remaining
to: "00:05:00"
What’s the best way to implement this?
The remaining attribute doesn’t update live, it updates when the timer is pause, cancelled, or finishes. I think the closest you can get (though not super accurate due to how templates based on now() update) is to use a template trigger:
    value_template: |
      {% set t_finish = state_attr('timer.kids_bath_fan_timer','finishes_at') %}
      {{ false if t_finish is none else t_finish | as_datetime - now() <= timedelta(minutes=5) }}
this one’s a tough request (at least for me)… an interesting puzzle on how to do this at all cleanly. i have a way for you, but it’s more complicated and messy than @Didgeridrew 's one liner template…
but template sensors like that only update once at minute, and not necessarily on the minute boundary you may want…
if i had to do this i think i’d create a “5 minute left timer”… and that timer was set each time the main timer was started or restarted… cancelled when the main timer was cancelled or finished. and when stated, set the “5 minute left timer” again:
much easier if you can count on the timer never pausing and restarting… but anyways, here’s what i got for ya:
alias: handle test timer start
  - platform: event
    event_type: timer.started
    event_data:
      entity_id: timer.test_timer
  - platform: event
    event_type: timer.restarted
    event_data:
condition: []
  - service: timer.start
      entity_id: timer.five_min_left_timer
      duration: >
        {{ (strptime( state_attr('timer.control4_heartbeat_received',
        'remaining'), '%H:%M:%S') - timedelta(minutes=5)).time()}}
and this:
alias: handle test timer stop events
  - platform: event
    event_type: timer.finished
    event_data:
  - platform: event
    event_type: timer.cancelled
    event_data:
  - platform: event
    event_type: timer.paused
    event_data:
condition: []
  - service: timer.cancel
Didn’t realize this would be so complicated. Yikes!
For full context, I’m looking to DIY a fancy bath fan timer using a Zooz ZEN32 scene switch Zooz 800 Series Z-Wave Long Range Scene Controller Switch ZEN32 800LR - The Smartest House . The four scene buttons will set the fan to run for 5, 10, 15, or 30 minutes. And I want the scene button LEDs to update as it progresses.
For example, when there’s a 30min request, we illuminate the 30min button and leave the others off. When there’s 15min left on the timer, the 15min button’s LED should turn on and the others turn off. And so on for the 10- and 5-minute buttons.
@Digeridrew might be on the right track by focusing on the finishes_at time, assuming the now() timedeltas are precise enough.
@armedad ‘s solution also gives me an idea. The desired function here will always be in 5-minute blocks between 5 and 30min. So all I need to do is define the number of iterations through a 5-minute loop, and perhaps update the number of iterations with new inputs as necessary.
Gonna noodle on these for a bit.
now() and timedeltas are precise for when they are called. the issue you’re going to have is that the sensors you write will update only on minute granularity. so it can be in the extreme 59 seconds off. but averaged 30secs off. if that’s ok, then his method is definitely simpler!
if you think you will always only start and stop, then you can simplify my approach a bit.
I think it would be helpful if additional data can be passed to a timer (as an attribute) each time you start, pause, or resume it.
Is stead of needing multiple timers (like 30 minutes and a 5 minute timer), one timer can be used with a state value:
  • First start set the timer 25 minutes and a state value first step
  • When finished, you that can start the timer again for 5 minutes and state value second step
This would enable to create automations that use one timer , to act as a state machine
I like that! Add this to the feature request section and I’ll happily vote for it :slight_smile:
@brystmar
I’m not sure that the Remaining value does update even after pausing or ending. I created an automation that is meant to trigger when Remaining drops below 600 (which per the docs seems to be the correct way to specify 10 minutes, since the Numeric trigger input field won’t accept a time), but so far I have been unable to get it to trigger at all. I have tried pausing above & below the threshold, restarting, letting the timer run out, etc. – no new traces.
(P.S. I am now replying to you on two separate threads, Didgeridrew. Pure coincidence and I hope it’s not a bother! Wanted to keep everything in its correct topic.)
It does.
That attribute is a time-formatted string, not a number, so it will never fire a Numeric state trigger.
There really isn’t a great way to trigger off an offset from a timer entity’s projected completion. The best way I know of requires setting up a Template Sensor Helper that takes it’s state from the finishes_at attribute of the timer entity and is of the “timestamp” Device Class.
That will give you an entity that can be used it in a Time trigger. You can define an offset in the trigger.
It’s possible to do with a Template trigger, but it’s less accurate than using the method above because the template only updates at the top of each minute. So the automation can fire as much as 59 seconds after the offset is reached.
I added a feature request here
