i am using Hass IO sucessfully since years. But currently I am getting completely lost because I dont understand why my Automations dont trigger anmore when I use numeric_state as plattform:
and 0.864 is in my understanding above 0.3 Why does the automation not trigger? If I execute the automation manually the message is correclty delivered via pushover, so there is not the mistake. Like said, the Automation does not trigger
Have you tried using a different trigger? Time pattern, perhaps. You could have it fire every 10 minutes (for example - I don’t know how often your exchange rate sensor is updated) with a condition so that the notification is sent if the sensor value is above 0.x.
