tomtaylor
(Tom Taylor)
September 18, 2022, 5:07am
1
This must be some obvious thing but I’m unable to find it out.
I’ve an automation following the syntax from https://www.home-assistant.io/docs/automation/trigger/#numeric-state-trigger :
alias: Pantry AutoOff
description: ""
- platform: device
type: turned_on
device_id: 71e518f09491619bb9ef2524460c16db
entity_id: light.pantry_light_ha102_light
domain: light
for:
seconds: "{{ states('input_number.pantry_autooff_delay') | int(600) }}"
condition: []
- type: turn_off
domain: light
mode: single
Receiving the following error:
“Message malformed: expected float for dictionary value @ data[‘for’][‘seconds’]”
My template evaluates properly:
Any idea what’s wrong with it?
tom_l
September 18, 2022, 6:25am
2
No you dont.
You have a device trigger. They are awful and they do not support templates.
Read the document you linked to again.
tomtaylor
(Tom Taylor)
September 19, 2022, 2:12am
3
Hi tom_l,
Thanks for your prompt response. Fair enough.
My revised solution:
description: ""
- platform: state
entity_id:
- light.pantry_light_ha102_light
to: "on"
for:
seconds: "{{ states('input_number.pantry_autooff_delay')|int(30) }}"
condition:
- condition: template
value_template: >-
{{ iif(states('input_number.pantry_autooff_delay')|int(0) == 0, 'False',
'True') }}
- type: turn_off
domain: light
mode: single
Still not sure if this is the most elegant way to do it but it seems to work.
Also added a condition to disable automation when “pantry_autooff_delay” set to zero. I’ve tried to acheive the same by adding “enabled: …” to trigger but it does not seem like a template friendly contruction either or at least I could not make it work.
Pls share any better way to implement this. I’m happy to learn.
Thx, T.
tom_l
September 19, 2022, 2:18am
4
Very good. You can change the condition to this:
value_template: >
{{ states('input_number.pantry_autooff_delay')|int(0) != 0 }}
The inequality test will return true or false for you.
Though valid, you’re still using device actions. This would be better :
- service: light.turn_off
tomtaylor
(Tom Taylor)
September 19, 2022, 4:13am
5
Really cool, appreciate it!
