Automation trigger for video stream failed
I have a frigate integration which it get its feed from a standalone go2rtc. The go2rtc may require a reboot from time to time. Is there a way to trigger an automation when the stream is not working?
When the go2rtc thing requires a reboot, can you ping it? IE is there a way to detect if it’s not available?
If you can determine a trigger, then have some way of interrupting the power or pushing the reset button, you have what you need.
This could help if it stops pinging when it needs reset…
https://github.com/SirGoodenough/HA_Blueprints/blob/c05d6fb431c1d84cb145c7d6dd5ffe5a60b1d9e2/Automations/Device_tracker_Monitor_and_Notifier.md.
Thanks for your reply.
go2rtc, frigate and hass are just containers running on the same machine. The machine runs fine. The go2rtc process requires a restart though.
OK, find a way to test it, put that logic into a boolean, and write an automation to restart it.
Or get real data on what’s happening and write an issue up to the go2rtc repo.
