Hi!
I want to make an automation for a PIR sensor, but a little more advanced.
As far as I know, there are only two types of PIR sensors:
- One which does not matter if sees motion for longer time than the cooldown time, it will go to clear (after the cooldown time), then it will trigger again for motion (I had some RF PIR sensors like this).
- The second type of PIR sensors, which I think it is the most common: if there is motion, it will have “detected” state, if no motion for 5 seconds, it will go to “clear” state (this means that if I will move one hour in front of the device, he will not change state, it will keep “detected”)
So, based of this second type of PIR sensors, which I also have, I want to make an automation which will trigger everytime the PIR sensor will have the same “detected” state for more than 5 seconds. So, if I move for 22 seconds, the automation should trigger 4 times.
I already made an automation for this, it is working, but I want to know if there is a better approach. This is what I have:
triggers:
- trigger: state
entity_id:
- binary_sensor.computer_2_presence_pir_sensor
to: "on"
for:
hours: 0
minutes: 0
seconds: 5
conditions: []
actions:
- action: persistent_notification.create
metadata: {}
message: Motion
- action: python_script.set_state
metadata: {}
entity_id: binary_sensor.computer_2_presence_pir_sensor
state: "off"
- action: homeassistant.update_entity
metadata: {}
entity_id:
mode: single
I could use the python_script.set_state for off and on, but I wanted to use update_entity for on, don’t ask me why (brain fixations)
The automation will trigger again in 5 seconds, if “the state is the same” by “restarting” the state with the help of the last two actions from automation, but is this the right approach? There is no other better solution? Maybe something wihtout using “python_script.set_state” ?
