I have several temperature sensors all around and I want an automation to send a notification in case any of these sensors report unusually high temperature. Some of my temperature sensors report the temperature in their state while others in attribute. I came up with a loop to go through all the sensors and check if any of them has ‘temperature’ in name or attribute. If any of them exceeds the threshold
the automation is triggered and a notification to be sent.
To check the sensors I iterate through all the sensors with a for loop
- alias: Unusually High Temperature Warning
platform: template
value_template: >-
{%- set threshold = 40 -%}
{%- for item in states.sensor %}
{% if (item.attributes.temperature is defined and item.attributes['temperature']|int > threshold) or ("temperature" in item.entity_id|lower and ((item.state|int > threshold and item.state|int != 0))) or ("temperature" in item.name|lower and ((item.state|int > threshold and item.state|int != 0))) -%}
{{ true }}
{% endif %}
{%- endfor -%}
- service: notify.ios_xxx
title: "Smart Home"
message: "A sensor reports high temperature."
After saving and reloading automations CPU usage goes constantly above 30% and the entire Home Assistant system slows down and reacts with like 10-20 seconds delay. It seems the loop is killing the system. As soon as I remove the code and reload automations everything goes back to normal.
My question is why this is not working if a template trigger should only check for trigger condition if a sensor is changing it’s state?
I have another similar automation based on a suggestion from this forum, checking for dead nodes in z-wave network and this one works perfectly without any problem:
- alias: Z wave dead node detection and notification
platform: template
value_template: >
{%- for state in states.zwave -%}
{%- if state.state == "dead" or (state.attributes.is_failed is defined and state.attributes['is_failed'] == true) -%}
{{ true }}
{%- endif -%}
{%- endfor -%}
data_template:
title: Smart Home
message: "Dead nodes found"
subtitle: "Z-wave Malfunction"
I created my temperature check automation based on this, but it doesn’t work properly as I mentioned before. Thanks for help!
