Automation trigger time
I am trying to get a workday morning light automation to work but cant get the time trigger to work. I can activate the automation manually.
Here is my code:
  - id: Morgon ljus arbetsdagar
    alias: Morgon ljus arbetsdagar
      platform: time
      at: '05:45:00'
    condition:
      condition: and
      conditions:
        - condition: state
          entity_id: 'device_tracker.victor_c4a9ed9a821b453c8f61b87819bd1a64'
          state: 'home'
        - condition: state
          entity_id: 'binary_sensor.workday_sensor'
          state: 'on'
      - service: light.turn_on
        entity_id: light.kok_taklampa
        data_template:
          color_temp: 450
          brightness: 125
        entity_id: light.hall_lampa
        data_template:
          color_temp: 450
          brightness: 125
Can you format your code per the blue box at the top of every post?
Are your conditions met at 5:45? the device tracker is home and the binary sensor is ‘on’
Double check your entity IDs and the states using the developer tools states tab. the difference between a state of ‘ON’ vs. ‘on’ has tripped up others in the past.
Yes my conditions are met at 5:45 even tried whith only the trigger and not the conditions but still no luck.
tried this one but still no luck. It works when i activate it manually but not on the trigger
    - platform: time
      at: "22:30:00"
    - service: homeassistant.turn_on
try…
    - platform: time
      at: '22:30:00'
still no luck.
    - platform: time
      at: '23:05:00'
You have no template so shouldn’t that be data instead of data_template?
        data_template:
          color_temp: 450
          brightness: 125
This thread talks about a time triggering problem that was due to incorrect timezone. Maybe it applies to your situation?
dont know the data/data_template part but the automation works when i trigger it manually
And as you pointed out it was a timezone problem i was 1 h off…
thank you so much
You’re welcome! Glad to hear it helped you resolve the problem.
From all examples I’ve seen, data_template is used when it has an actual template (Jinja2). I think what you have works because it doesn’t care if the template is missing. However, if it were the other way around, meaning it says data: but also contains a template, then that probably wouldn’t work.
