Automation trigger: Using a template to generate a list of entity_ids
I’ve written this automation to try and generate a list off entity_id’s in the trigger. Needless to say it doesn’t work.
automation:
  - alias: 'Lights: Movement in hallway'
    mode: queued
      - platform: state
        entity_id: binary_sensor.hallway_motion_occupancy
        to: "on"
      - platform: state
        entity_id: >
          {% set trigger = 'hallway_motion_occupancy' %}
          - {{ states.binary_sensor
            | selectattr('entity_id','match','.*_motion_occupancy')
            | rejectattr('entity_id','match','binary_sensor.'~trigger)
            | rejectattr('entity_id','search','patio')
            | rejectattr('entity_id','search','front')
            | map(attribute='entity_id')
            | list
            | join('\n- ')
        to: "on"
It certainly looks like a list of entity_ids when I do this in settings ➜ template:
Screenshot 2024-08-07 at 14.14.04
I realise result type: string isn’t helping, but removing both join() & the preceding - to create a list doesn’t work either.
My logs doesn’t really tell me why it is failing only that it:
failed to setup triggers and has been disabled: Entity {% set trigger = ‘study_motion_occupancy’ %} {{ states.binary_sensor | selectattr(‘entity_id’ is neither a valid entity ID nor a valid UUID for dictionary value @ data[‘entity_id’]. Got None
Is this possible and, if so, what am I doing wrong?
The State Trigger doesn’t support templates. Consider using a Template Trigger.
thanks - good to know that I wasn’t going completely mad!
No worries, it’s a common assumption. It would be handy if a State Trigger’s entity_id option supported templates but it currently doesn’t.
NOTE
Even if it did support templates, what you created still wouldn’t work.
Your template produces a list in YAML format. Don’t use templates to generate YAML code in triggers, Template Sensors, etc.
This would be the acceptable way to generate a list:
            | list }}
This reminded me a related question:
Consider these different triggers:
- platform: state
  entity_id:
    - binary_sensor.xxx_1
    - binary_sensor.xxx_2
    - binary_sensor.xxx_3
  to: on
  value_template: >-
       selectattr('entity_id','search','binary_sensor.xxx_') |
       selectattr('state','==','on') |
       list | count > 0 }}
Which trigger consumes more CPU time?
thanks!
I was trying the following as you posted :slight_smile:
          {% set trigger = 'study_motion_occupancy' %}
            | rejectattr('state','eq','off')
            | list
            | count
It’s a good question - I imagine the template one consumes more, but I don’t know for sure.
My rational for using the template is that it’s more ‘future proof’ (for when if I add more motion sensors and forget to update this particular automation). Also, I have several like this and was thinking of turning it into a blueprint.
Here’s how a Template Trigger is triggered:
So your template will trigger when the count changes from 0 to a positive integer (like 1). Any additional changes involving positive numbers will not serve to trigger it again. The count must first return to 0 and then change to a positive integer in order to trigger it. Any positive number is considered to be true and it must first change back to false (0) before it can be triggered again.
Example:
  • Assume all motion sensors are off.
  • Now one motion sensor turns on. It will trigger the automation because the count changes from 0 to 1.
  • While the motion sensor is still reporting on, a second motion sensor turns on.
  • The count changes from 1 to 2 but it won’t serve to trigger the Template Trigger again.
FWIW, petro has submitted a PR that would provide the Template Trigger with an option to trigger whenever its template’s result changes.
All this to say that the Template Trigger you have created doesn’t replicate the behavior of a State Trigger that will trigger whenever any of its monitored entities changes state (and there’s no way to do it currently).
Means - this template will work ONCE when some entity changes OFF-> ON
  value_template: >-
       list | count > 0 }}
and will not be triggered again when ANOTHER entity changes OFF-> ON.
I.e. - not same functionality as
- platform: state
  entity_id:
  to: on
Exactly.
Yes, that was what I wanted (in this instance).
Basically, this is “switch on light if you are in that room and switch it off if you are anywhere else”.
The Template Trigger will be adequate provided this scenario is acceptable for your needs:
  • Person walks into bedroom, the bedroom motion sensor is turned on, automation is triggered.
  • While bedroom motion sensor is still reporting on, a second person walks into kitchen, the kitchen motion sensor is turned on, automation is not triggered.
Yes, that is correct. You haven’t seen the whole automation - there is a condition that input_bookean.single_occupancy is on. If off, the automation will not respond to that trigger but, instead use timers and the continued motion detection in that room. I’ll post the full automation in a minute for info.
Here is the full package (but it uses some entities not defined here (eg: input_select.house_mode).
Package
input_boolean: #----------------------------------------------------------------
  hallway_light_awake:
    name: Allow Hallway motion (awake)
  hallway_light_asleep:
    name: Allow Hallway motion (asleep)
  hallway_light_triggered_by_motion:
    name: Hallway light triggered by motion
input_number: #-----------------------------------------------------------------
  hallway_light_awake_level:
    unit_of_measurement: "%"
    min: 50
    max: 100
    step: 10
    icon: mdi:brightness-percent
  hallway_light_awake_time:
    unit_of_measurement: "min"
    min: 0.5
    max: 5
    step: 0.5
    icon: mdi:timer
  hallway_light_awake_warning_level:
    name: Warning brightness (awake)
    min: 5
    max: 30
    step: 5
  hallway_light_awake_warning_time:
    name: Warning timer (awake)
    min: 0.5
    max: 3
    step: 0.5
    icon: mdi:timer
  hallway_light_asleep_time:
    min: 0.5
    max: 5
    step: 0.5
    icon: mdi:timer
input_select: #-----------------------------------------------------------------
  hallway_light_level:
    name: "Allow Hallway motion when light is"
    icon: mdi:sunglasses
    options:
      - "Any"
      - "Grey or less"
      - "Dark or less"
      - "Night"
timer: #------------------------------------------------------------------------
  hallway_light:
    icon: mdi:timer
    duration: "00:02:30"
    restore: true
  hallway_light_warning:
    icon: mdi:timer
    restore: true
automation: #-------------------------------------------------------------------
    mode: queued
      # activation sensor(s)
      - platform: state
        to: "on"
      # cancelation sensor(s) - single_occupancy_mode
        value_template: >
            | selectattr('state','eq','on')
            | list
            | count > 0
      # timers
      - platform: event
        event_type: timer.finished
        event_data:
          entity_id: timer.hallway_light
      - platform: event
        event_data:
          entity_id: timer.hallway_light_warning
      # house_mode
      - platform: state
        entity_id: input_select.house_mode
        to: "Asleep"
    condition: "{{ states('input_boolean.lux_scenes_locked') == 'off' }}"
      - choose:
          # start ------------------------------
          - conditions:
              - "{{ trigger.id == 'motion_detected'}}"
              - "{{ states('light.hallway') == 'off' }}"
              - or: # house_mode
                  - and:
                      - "{{ states('input_select.house_mode') == 'Awake' }}"
                      - "{{ states('input_boolean.hallway_light_awake') == 'on' }}"
                  - and:
                      - "{{ states('input_select.house_mode') == 'Asleep' }}"
                      - "{{ states('input_boolean.hallway_light_asleep') == 'on' }}"
              - or: # light_level
                  - "{{ states('input_select.hallway_light_level') == 'Any' }}"
                  - and:
                      - "{{ states('input_select.hallway_light_level') == 'Grey or less' }}"
                      - "{{ states('sensor.light_level') in ['Grey','Dark','Night'] }}"
                  - and:
                      - "{{ states('input_select.hallway_light_level') == 'Dark or less' }}"
                      - "{{ states('sensor.light_level') in ['Dark','Night'] }}"
                  - "{{ states('sensor.light_level') == 'Night' }}"
            sequence:
              - service: light.turn_on
                  entity_id: light.hallway
                  transition: 1
                  brightness_pct: "{{ iif(is_state('input_select.house_mode','Awake'),states('input_number.hallway_light_awake_level'),1) }}"
                  entity_id: input_boolean.hallway_light_triggered_by_motion
              # start timer if not using cancelation sensors (single-user mode)
              - if: "{{ states('input_boolean.single_occupancy_mode') == 'off' }}"
                then:
                  - service: timer.start
                      duration:  "{{ iif(is_state('input_select.house_mode','Awake'),states('input_number.hallway_light_awake_time')|float*60,states('input_number.hallway_light_asleep_time')|float*60) }}"
                  # cancel warning timer (just in case - prob not needed)
                  - service: timer.cancel
          # extend -----------------------------
          - conditions:
              - or:
                  - "{{ states('timer.hallway_light') == 'active' }}"
                  - "{{ states('timer.hallway_light_warning') == 'active' }}"
            sequence:
              # light (back) to non-warning level
                  transition: 1
              # restart timer
          # warning if no motion detected ----------------------------
          - conditions: "{{ trigger.id == 'timer_finished'}}"
            sequence:
              - if: "{{ states('binary_sensor.hallway_motion_occupancy') == 'on' }}"   # motion detected
                then:
                  # restart timer
                      #duration:  "{{ iif(is_state('input_select.house_mode','Awake'),150,30) }}"
                else:
                  # dim light
                      transition: 1
                      brightness_pct: "{{ iif(is_state('input_select.house_mode','Awake'),states('input_number.hallway_light_awake_warning_level'),1) }}"
                  # start warning timer
                      duration:  "{{ iif(is_state('input_select.house_mode','Awake'),states('input_number.hallway_light_awake_warning_time')|float*60,1) }}"
          # cancel / finish -----------------------------
          - conditions:
              - or:
                  - "{{ trigger.id == 'warning_finished'}}"
                  - "{{ trigger.id == 'asleep_cancel'}}"
                  - and:
                      - "{{ trigger.id == 'single_occupancy_cancel'}}"
                      - "{{ states('input_boolean.single_occupancy_mode') == 'on' }}"
                      - "{{ states('input_boolean.hallway_light_triggered_by_motion') == 'on' }}"
            sequence:
                  entity_id:
                    - timer.hallway_light
                    - timer.hallway_light_warning
              - service: light.turn_off
                  transition: 1
              - service: input_boolean.turn_off
