Automation trigger when value is not changing for some time
Hi
How can I make an automation/ trigger only when a sensor is not changing the (latest) value for a hour? So inactivity.
Thanks!
  - platform: state
    entity_id: sensor.whatever
    to:
    for:
      hours: 1
Then null to: monitors all state changes but ignores attribute changes. If you are interested in attributes of the sensor not changing as well then leave that part out.
should I set the ā€œtoā€ to ā€œunknownā€ status or ā€œnot availableā€? it seems that the state of an entity remains at the last value when I look at the history of the sensor.
You can monitor the value of the entityā€™s last_changed property.
In the following example, if the value of the sensorā€™s last_changed property hasnā€™t changed in over an hour, it sends a notification.
alias: example
    value_template: >
      {{ now() - states.sensor.temperature.last_changed >= timedelta(hours=1) }}
  - service: notify.persistent_notification
      title: Stale Temperature
      message: >
        {{ now().timestamp() | timestamp_local }} Value unchanged for the past hour.
Another example, demonstrating how to periodically check multiple sensors.
No leave it empty. That way HA will trigger on any state that persists for an hour. It will ignore attribute changes.
If you delete the to: altogether then HA only triggers if the state and attributes have the same values for an hour.
Thank you both! I suppose both suggested solutions will accomplish the same?
I believe thereā€™s a subtle difference that may or may not be important to you. The difference is how they initially behave upon implementation.
  • After implementing the version employing a State Trigger, it will require the entity to undergo at least one state-change before it can detect if that state-change becomes stale (i.e. remains unchanged for an hour or more).
  • After implementing the version employing a Template Trigger, it will immediately detect if the entityā€™s state is stale.
And neither one will work after Home Assistant restarts, right? Because for some reason last_changed still doesnā€™t persist past restarts
For good reason.
When Home Assistant starts it has no idea what has happened to all the entities while it was off-line. So it makes them all unknown until they are restored or updated.
Changing from unknown ā†’ some state will cause the last_changed property to update.
I donā€™t think itā€™s for good reason. It should be optimistic about last_changed. With every restart, we lose all states. Tons of other people agree
Fortunately for us the developers disagree with you.
Unfortunately for us, you mean. Nothing stopping them from adding an additional, optimistic field if theyā€™re so worried about what happens to last_changed while HA is off
That is not what they are worried about. The indeterminate state of all entities is the issue. Updating last changed is just a by-product of initialisation.
try working on same trigger. It seems not fire up. my HA core is 2024.11.1 (frontend 20241106.2). The coding is below
alias: Battery Low Warning - čµ°å»Ščæ‡é“
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.miaomiaoce_t2_00a4_battery_level
    to: unavailable
    for:
      hours: 0
      minutes: 5
      seconds: 0
    enabled: false
  - trigger: state
    entity_id:
      - sensor.miaomiaoce_t2_00a4_temperature
    for:
      hours: 0
      minutes: 2
      seconds: 0
conditions: []
actions:
  - data:
      message: äø»å§ęø©ę¹æč®”ē”µę± éœ€č¦ę›“ę¢äŗ† at {{now().strftime('%H:%M %A %d %B %Y') }}
    action: notify.mobile_app_cph2305
mode: single
