Automation triggered, but service: alarm_control_panel.alarm_disarm not really executed
Automation is correctly triggered
All actions are logged as executed (both in automation log and general log)
Last action “service: alarm_control_panel.alarm_disarm” not really executed (also logged as executed)
If I trigger the automation manually all is executed correctly.
I’m lost in this. Checked and checked again…
Thank in advance
Here the automation code:
alias: 'Allarme: DIS perimetrale per vento'
description: ''
  - platform: numeric_state
    entity_id: sensor.10_min_average_wind_speed
    above: '5'
condition:
  - condition: or
    conditions:
      - condition: state
        entity_id: alarm_control_panel.perimetrale
        state: armed
      - condition: state
        state: armed_away
  - service: tts.google_say
      message: Wind > Alarm off
      entity_id: media_player.gruppo_casa
  - service: notify.persistent_notification
  - service: alarm_control_panel.alarm_disarm
mode: single
Hi katangus, welcome to the forums.
Does your alarm need a code to be disarmed?
thank you!
no, code is not needed.
To be sure: The alarm has been armed, the automation is triggered, but the alarm won’t be disarmed, right?
Exactly.
But the very strange things is that if now I trigger r automation manually the alarm is disarmed.
In all the situation I got all the notification defined
This is intended; basically, the manual triggering should work.
Is the service alarm_control_panel.alarm_disarm working, when you call it in the Developer Tools or in a most simple automation?
Yes, both.
Can you please add a delay of let’s say 10 seconds between service: notify… and service: alarm… ?
no changes
Can you try reducing the action: to just the disarm service call and try it.
