Automation triggered by Daylight savings change with Shelly Devices
We just went into Daylight Savings here which is triggering the automation rules I have linked to Shelly relays from a device state change.
I presume it reboots to apply the timezone change?
In this example the Master Bedroom switch is connected to a Phillips hue bulb, that was already off - the rocker switch was in the on state but turned off by voice commands outside of HA. so because the automation ran it turned the bulb on.
Any recommendations for the best way of handling this?
Its not a problem if the automation runs and the switch is in the correct position - it will just re-apply how it already was. However my preference even in this scenario would be to find a way to avoid running the automation when it wasn’t actually chosen be it caused by Daylight Savings or a power cut etc? Can anyone think of a good solution?
