I have a simple automation setup. The trigger is KeypadLinc Button D turned on. The action is to turn on an Outdoor On/Off Module. If I manually execute the automation, the On/Off module is correctly turned on. If I push the D Button, the module is NOT turned on. I have confirmed in the Logbook that the Button D is fired and that the automation is triggered. Yet the module is never turned on. I can obviously turn on the outdoor module via the entity without a problem. It seems like the USB controller is “busy” still receiving data from the Keypad and the ACK is never received.
41009e is the KeypadLinc and 3f94f6 is the Outdoor On/Off module
Has anyone else seen behavior like this? I’ve also had what appears to be similar problems with Insteon Motion Sensors and Door Sensors when controlling Insteon Switches through an HA automation.
The first set of logs below is from physically pushing the KeypadLinc Button. Outdoor On/Off Module is not turned on.
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 41009e, target: 000006, flags: 0xcf, cmd1: 0x11, cmd2: 0x00
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: 41009e.6.on.all_link_broadcast data: {'cmd1': 17, 'cmd2': 0, 'target': 000006, 'user_data': None, 'hops_left': 3}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.41009e.6.on.all_link_broadcast data: {'on_level': 255}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: subscriber_41009e_on_6_broadcast data: {'on_level': 255}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: state_41009e_on_off_switch_d_6 data: {'name': 'on_off_switch_d', 'address': '41009e', 'value': 255, 'group': 6}
2020-11-05 22:18:26 DEBUG (MainThread) [homeassistant.components.insteon.insteon_entity] Received update for device 41009e group 6 value 255
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: event_41009e_6_on_event data: {'name': 'on_event', 'address': '41009e', 'group': 6, 'button': 'on_off_switch_d'}
2020-11-05 22:18:26 DEBUG (MainThread) [homeassistant.components.insteon.utils] Firing event insteon.button_on with {'address': '41009e', 'button': 'd'}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: send.on.direct data: {'address': 3f94f6, 'on_level': 255, 'group': 1}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.on.direct data: {'msg': msg_id: 0x62, address: 3f94f6, flags: 0x00, cmd1: 0x11, cmd2: 0xff, 'priority': 3}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 3f94f6, flags: 0x00, cmd1: 0x11, cmd2: 0xff
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 41009e, target: 3d9877, flags: 0x40, cmd1: 0x11, cmd2: 0x06
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: 41009e.6.on.all_link_cleanup data: {'cmd1': 17, 'cmd2': 6, 'target': 3d9877, 'user_data': None, 'hops_left': 0}
2020-11-05 22:18:26 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.41009e.6.on.all_link_cleanup data: {}
2020-11-05 22:18:27 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 41009e, target: 110106, flags: 0xcb, cmd1: 0x06, cmd2: 0x00
2020-11-05 22:18:27 DEBUG (MainThread) [pyinsteon.topics] Topic: 41009e.6.all_link_cleanup_status_report.all_link_broadcast data: {'cmd1': 6, 'cmd2': 0, 'target': 110106, 'user_data': None, 'hops_left': 2}
The second set of logs is from me turning on the Outdoor Module via the entity. Outdoor Module is correctly turned on.
2020-11-05 22:20:52 DEBUG (MainThread) [pyinsteon.topics] Topic: send.on.direct data: {'address': 3f94f6, 'on_level': 255, 'group': 1}
2020-11-05 22:20:52 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.on.direct data: {'msg': msg_id: 0x62, address: 3f94f6, flags: 0x00, cmd1: 0x11, cmd2: 0xff, 'priority': 3}
2020-11-05 22:20:52 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 3f94f6, flags: 0x00, cmd1: 0x11, cmd2: 0xff
2020-11-05 22:20:52 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 3f94f6, flags: 0x00, cmd1: 0x11, cmd2: 0xff, ack: 0x06
2020-11-05 22:20:52 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.3f94f6.1.on.direct data: {'cmd1': 17, 'cmd2': 255, 'user_data': None}
2020-11-05 22:20:53 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 3f94f6, target: 3d9877, flags: 0x26, cmd1: 0x11, cmd2: 0xff
2020-11-05 22:20:53 DEBUG (MainThread) [pyinsteon.topics] Topic: 3f94f6.on.direct_ack data: {'cmd1': 17, 'cmd2': 255, 'target': 3d9877, 'user_data': None, 'hops_left': 1}
2020-11-05 22:20:53 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.3f94f6.1.on.direct data: {'on_level': 255}
2020-11-05 22:20:53 DEBUG (MainThread) [pyinsteon.topics] Topic: state_3f94f6_on_off_switch_1 data: {'name': 'on_off_switch', 'address': '3f94f6', 'value': 255, 'group': 1}
2020-11-05 22:20:53 DEBUG (MainThread) [homeassistant.components.insteon.insteon_entity] Received update for device 3f94f6 group 1 value 255
2020-11-05 22:20:53 DEBUG (MainThread) [pyinsteon.topics] Topic: event_3f94f6_1_on_event data: {'name': 'on_event', 'address': '3f94f6', 'group': 1, 'button': 'on_off_switch'}
2020-11-05 22:20:53 DEBUG (MainThread) [homeassistant.components.insteon.utils] Firing event insteon.button_on with {'address': '3f94f6'}
