I’m trying to trigger a automation via sun.sun state.attributes.anzimuth:
automation:
- alias: 'Raffstore Ost runter'
initial_state: true
hide_entity: True
platform: numeric_state
entity_id: sun.sun
value_template: '{{ state.attributes.anzimuth }}'
above: 31
condition:
condition: state
entity_id: input_boolean.raffstore_sommermodus
state: 'on'
- service: cover.close_cover
entity_id: cover.cover_eg_kueche, cover.cover_eg_ezs, cover.cover_og_le, cover.cover_eg_sz
- service: notify.mail
title: 'Raffstore Ost runter'
message: 'test'
- alias: 'Raffstore Ost runter test'
initial_state: true
hide_entity: True
platform: template
entity_id: sun.sun
value_template: '{{ state.attributes.anzimuth > 31 }}'
condition:
condition: state
state: 'on'
message: 'test'
but they are both not working!
How can this be implemented?
damn it, your right it’s azimuth!
I’ll try it with the correct spelling, strange that the config is valid with a non existing state…
Probably can’t evaluate it on that level
Some times you just get blind looking for errors
The automation is triggerd when I set
sun.sun to
"azimuth": 30
and then to
"azimuth": 31
via the developer tools --> states in HA
but not when the sun component is actually changing!
Perhaps the suggestion in this post will help you
Try this:
- alias: 'Temperature warning'
platform: state
entity_id: sensor.living_room_temperature
condition:
condition: template
value_template: '{{ (states("sensor.living_room_temperature") | float) < (states("input_slider.warning_temperature") | float) }}'
- service: notify.notify
data_template:
message: 'Temperature: {{ states.sensor.living_room_temperature.state }} {{ states.sensor.living_room_temperature.attributes.unit_of_measureme…
float doesn’t help.
I fixed it with moving the automation part from
.homeassistant/packages/raffstore.yaml
to
.homeassistant/automation.yaml
which shouldn’t make any difference, since I have some other yaml files in the packages directory, included it in configuration.yaml and they are working fine.
packages: !include_dir_named packages
So there is a problem with sun.azimuth inside a package.
You have to name files according to what you keep in them if you use !include_dir_named.
!include_dir_named will return the content of a directory as a dictionary which maps filename => content of file.
Parsing the configuration files has nothing to do with the sun component.
