Hi all,
First timer at this here and I’ve run into an issue that I can’t seem to debug.
I have an automation that turns my Alarm Panel to Armed and to Disarmed at scheduled times. I have noticed on several occasions that the automation runs, but doesn’t actually execute the action properly. As part of my arm automation I have it set to turn on my outside lights at the same time as arm. The lights will dim, but the panel never goes to arm. If I hit Trigger it will then run. This is also the case for disarm. Most mornings I will see that my alarm panel is still armed and I need to enter the pin code or hit Trigger on my automation and it will disarm.
Bear with me. I used the Automation piece in the configuration in Hassbian and it does a number on the ordering of the code.
Arm:
- action: - data: code: !secret_Alarm entity_id: alarm_control_panel.alarm_panel service: alarm_control_panel.alarm_arm_home - data: brightness_pct: '60' entity_id: light.outside service: light.turn_on - data: brightness_pct: '50' entity_id: light.living_room service: light.turn_on alias: Arm house nightly condition: [] id: '1515549462569' trigger: - at: 00:00:00 platform: time
Disarm:
- action: - data: code: !Secret_alarm entity_id: alarm_control_panel.alarm_panel service: alarm_control_panel.alarm_disarm alias: Disarm house condition: [] id: '1515549462570' trigger: - at: 05:00:00 platform: time
Thoughts?
