I have a automation that triggers on button hold and the second trigger in the automation is on the release of that button. But for some reason the release trigger sometimes does not work.
The delay of 5 minutes and the restart mode makes so that if you re-press the button within 5 min of releasing it, the ventilator won’t stop.
I assume it is as you want it?
No, I was under the impression that the “restart” mode made it so that the timer would restart and a new 5 min would start counting. The sensor part works great. The part triggered with the button does not (at least not every time)
Then the explanation in the documentation is not really clear on that.
I want the fan to turn on if one of the initial triggers get triggered. And the timer to restart when one of the initial triggers get triggered again within those 5 min. Also the timer should start only when the sensor has toggled to it’s original position. (the sensor is a modified contact sensor with a temp sensor to the warm water inlet of the shower)
My last effort was working flawlessly with my test sensor, test switch and test button and a 5 sec timer. But now that I set it up for the real deal after even one day it failed to turn off the fan switch. Please I really love some help as I am really desperate for answers.
alias: 1e badkamer ventilator aan en uit
description: ''
- platform: state
entity_id: binary_sensor.1e_badkamer_warm_water
- device_id: 9c05bef1cd794483a2fd923ad772d2aa
domain: deconz
platform: device
type: remote_button_long_press
subtype: turn_off
condition: []
- type: turn_on
device_id: b3e8ea8642f0619b4bc2073a52b4107c
entity_id: switch.1e_badkamer_ventilator
domain: switch
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- service: timer.start
duration: '00:05:00'
entity_id: timer.badkamer_ventilator_timer
- wait_for_trigger:
- platform: state
to: idle
- type: turn_off
domain: switch
default: []
mode: single
Ok, This morning it failed. But by the time I got to my computer I had already more then the 5 history states so the failed timeline had disappeared. Can I prolong the history states so I can see more then 5?
