Automation: trying to combine "platform: state" with "if, then, else"
Hi, i have setup an automation with 2 or more switches and lights to turn on/off using “platform: state”.
I would like to combine this with “if, this, else” but i have some trouble with the yaml code.
My goal is to automatically turn on the lights at 50% after sundown/before sunset when one of the switches are used.
This is the yaml without dimming the lights. I use this for all our lights/switches and it works perfect.
alias: test
description: ""
  - platform: state
    entity_id:
      - light.testlamp
      - switch.sonoff_10008c4c7a_1
    to: "off"
  - platform: state
    entity_id:
      - light.testlamp
    to: "on"
condition: []
  - service: switch.turn_{{ trigger.to_state.state }}
      entity_id:
  - service: light.turn_{{ trigger.to_state.state }}
      entity_id: light.testlamp
mode: restart
I tried this yaml code but that doesn’t work:
alias: test
description: ""
  - platform: state
    entity_id:
      - light.testlamp
    to: "off"
  - platform: state
    entity_id:
      - light.testlamp
    to: "on"
condition: []
  - if:
      - condition: time
        after: "23:00:00"
        before: "07:00:00"
    then:
          entity_id:
          brightness_pct: 50
          device_id: 3b4720b2c4952ac4747d9b4b97682e62
    else:
          entity_id:
          brightness_pct: 100
mode: restart
Can someone point me in the right direction here please?
You haven’t accounted for the “off” side of your triggers in the actions. I would also organize it a little differently.
alias: test
description: ""
  - platform: state
    entity_id:
      - light.testlamp
      - "on"
      - "off"
    to:
      - "on"
      - "off"
condition: []
  - choose:
    - conditions:
        - condition: template
          value_template: "{{ trigger.to_state.state == 'off'}}"
      sequence:
        - service: homeassistant.turn_off
            entity_id:
              - light.testlamp
    default:
      - service: switch.turn_on
          entity_id: switch.sonoff_10008c4c7a_1
      - service: light.turn_on
          brightness_pct: "{{50 if (now().hour >= 23 or now().hour < 7) else 100}}"
mode: single
Thanks for the quick reply. I never used a ‘template’ before.
The code works but the lamp doesn’t seem to dim to 50%. I changed the hours to a different value for testing but it always turns on to 100% brightness.
[edit] i used the same code on a different light and it works. Somehow the hue-bulb doesn’t seem to co-operate. The Sonoff-light works.
Is it possible to use this with the ‘sunset’ and sunrise’ value with an offset of 1 hour? I tried replacing ‘hour’ with ‘sunset/sunrise’ but no luck.
