I want to make an automation to turn off Air Conditioning when there is no person in the room longer than 60 minutes.
I use MQTT Tuya zigbee motion sensor - RH3040 and AC based on broadlink wifi card.
There is no roblem with control of AC from Home Assistant, so I only need to create automation.
What trigger should I create for Automation?
I hope you have integrated RG3040 with HA. If not you can follow this guide
You can use the RH3040 state as trigger like this.
- platform: state
entity_id: binary_sensor.bro_ping
to: 'off'
for: '01:00:00'
Instead of the my entity_id you should put RH3040 entity id. This looks for 60 minutes off state of that entity.
Do you have a sensor or something that shows when the room is occupied?
Then just trigger on the sensor going to off for 60 minutes.
platform: state
entity_id: binary_sensor.your_room_occupancy_sensor
to: 'off'
for:
hours: 1
Yes, sensor RH3040 is added to Home Assistant.
I will implement your solutions…
THX
Here it is. Could You look if everyting seems to be correct?
- id: '1612002981776'
alias: AC OFF when no movement during 1 hour
description: ''
- platform: state
entity_id: binary_sensor.0x5c0272fffecf6474_occupancy
to: 'off'
for: 01:00:00
attribute: occupancy
condition: []
- service: climate.turn_off
data: {}
entity_id: climate.living_room
mode: single
You have small corrections.
description: ''
- platform: state
to: 'off'
for: '01:00:00'
condition: []
data: {}
mode: single
It does NOT trigger
What to check why it is not?
Please share the sceenshot of state of the binary_sensor.0x5c0272fffecf6474_occupancy from the developer console.
Did you reload automations? Double check the entity_id. Is the automation enabled under Developer Tools -> States? Do you get an error under Configuration -> Logs?
I have forgotten to remove it. It seems to work now. But it looks like it started only one time.
It will only work when the binary sensor is off for 1 hour without any change.
Seems to by configured properly now and it works. THX for help:)
