Automation: Turn off all lights, except X
Hello!
I have an automation that turns all light off when all family members has left the house.
However, I want the lights in the windows to continue being on.
What would be a simple way of achieving this? :slight_smile:
This has worked for me. Test it in the template section once you modify the exclude.
  - service: home_assistant.turn_off
      entity_id: >-
        {% set domains = ['light','switch','fan','media_player'] %}
        {% set exclude = ['light.example1','light.example2'] %}
        {%- for device in states|selectattr('domain','in', domains)|rejectattr('entity_id','in',exclude)|selectattr('state','in','on') %}
          {%- if loop.first %}{%- else %},{% endif %}
          {{device.entity_id }}
          {%- if loop.last %}{% endif %}
        {%- endfor  %}
Hi, I am trying to use your script to turn off all lights except for the excluded ones. How ever the server: home_assistant.turn_off doesn’t exist. If I use homeassistant.turn_off and run it turns all lights off and doesn’t seem to exclude the list of lights I created. I tested this in the template section and the list of lights it creates is correct. Any ideas? Thanks!
It should be homeassistant.turn_off
Another way to do the same thing:
      entity_id: >
        {{ expand(states.light, states.switch, states.fan, states.media_player)
          | rejectattr('entity_id', 'in',  ['light.example1', 'light.example2', 'switch.whatever'])
          | selectattr('state', 'eq', 'on') | map(attribute='entity_id') | list }}
Yes agreed, but still not sure why it is simply turning all lights off I need it to execute the ignored lights
Try the template I posted above in the Template Editor.
If it lists the entities correctly, use Developer Tools > Services to test the entire service call (be sure to replace the original example’s data: with target:).
That worked perfectly not sure what I was doing wrong but this solved it, thanks so much!!
Tip:
If you have any Hue groups and you want to exclude them, you can add this line to the template:
  | rejectattr('attributes.is_hue_group', 'defined')
Great tips, thanks. Is it a bug or is it working differently with entity helpers for grouped lights. How can I include also those?
A light group entity has an attribute named entity_id that contains a list of light entities.
What do you want to do with it?
