I’m trying to create an automation that checks the temperature in a room, then, if below 21c turns on a switch attached to a heater, only if someone is home at a certain time. The issue is, if the temperature is below 21c when someone isn’t home, the trigger doesn’t re trigger when someone comes home. Would another automation be needed for when someone returns home?
This is my current automation.
automation:
- id: heater_on
alias: Heater On
platform: numeric_state
entity_id: sensor.wirelesstag_temperature
below: '21'
condition:
condition: and
conditions:
- condition: state
entity_id: group.family
state: 'on'
- condition: time
after: '18:00:00'
before: '07:00:00'
service: switch.turn_on
entity_id: switch.heater
Did @sparkydave’s suggestion solve your problem? If so, you should mark his post as the solution.
I did have another thought, though. The way you wrote your conditions it looks like maybe there’s a third trigger you may want – i.e., at 18:00:00. In other words, it seems you want to turn on the heater if 1) the temperature drops below 21, or 2) someone comes home (when nobody was home), or 3) at 18:00:00, but only if the temperature is below 21, and someone is home, and the time is between 18:00:00 and 07:00:00 (when any of the three triggers occur.) So basically:
automation:
- id: heater_on
alias: Heater On
- platform: numeric_state
below: 21
- platform: state
to: 'on'
- platform: time
at: '18:00:00'
condition:
- condition: numeric_state
below: 21
- condition: state
state: 'on'
- condition: time
after: '18:00:00'
before: '07:00:00'
Note that you don’t need to explicitly use condition: and since that is the default.
One other suggestion. Depending on how often your HA instance restarts, and what you want to do with the heater when it does, you may want to consider adding a fourth trigger:
- platform: homeassistant
event: start
With this added, when HA starts, if all three conditions are met, the heater will be turned on.
You can create a sensor template called heater_on.
sensors:
heater_on:
friendly_name: 'Heater On'
value_template: >-
{%- if (is_state("device_tracker.xxxx","home") or is_state("device_tracker.yyyy","home")) and (states.sensor.wirelesstag_temperature.attributes.state | int < 21)) -%}
True
{%- else -%}
False
{%- endif -%}
entity_id:
- device_tracker.xxxx
- device_tracker.yyyy
- sensor.wirelesstag_temperature
This sensor will become true when someone is at home and the temperature is below 21 regardless of time and will update if any entity changes state.
I divided your group into device trackers and use “or” in the template.
Then you should create an automation and check the time:
automation:
- id: set_heater_on
alias: Set Heater On
platform: state
entity_id: heater_on
to: 'on'
condition:
- condition: time
after: '18:00:00'
before: '07:00:00'
