Automation UI not working?
Is it just me or is the automation UI not working after upgrade to 0.58.1 in Hass.io?
One example is choosing a trigger for ‘sun’ and the options below is not shown (sunrise/sunset). Another issue is that I’m not able to save the automation I’ve created. No yellow 'Save* icon appear.
Yes it’s not working for me either. I think I posted about this but got no response. I thought it was just me. I was trying to create an automation with a time trigger but it didn’t change the input.
Weird thing is existing automations work and if I edit them I can save them. It’s just new automations that don’t seem to be working.
See: https://github.com/home-assistant/home-assistant-polymer/issues/681
I have the issue also in 0.58.1 so waiting for the release of 0.59
Me to all my automations have stoped working since upgrade pool pumps timer lights some use sun above or below horizon others just use time settings but nothing works anymore grrrrr
I have this issue as well. That is, the one where new triggers, etc. can be created and there’s no Save button.
I haven’t upgraded to 0.59 but it seems that there’s no fix for it in the changelog.
I just upgraded and it is working now.
But now i am trying to figure out if it is me or the upgrade but frontend.set_theme is not working for me. i can go into configuration and select a theme and it displays properly but service doesn’t seem to change it when called directly or used in an automation.
Automations editor was messed up even more after I upgraded hass.io to 0.59.1 (fields were missing), but then I added the following to configuration.yaml and it’s looking good.
frontend:
  javascript_version: latest
The only issue I have now is expected/known, where I can’t edit in the frontend automations that I previously edited manually.
