Hello everybody. Can you create a script to update Home assistant from a button? These would be the commands that I have to execute. Thank you so much
sudo -u homeassistant -H -s
cd /srv/homeassistant
python3.8 -m venv .
source bin/activate
pip install Homeassistant
dapuzz
(dapuzz)
June 15, 2021, 3:24pm
2
Just put this commands in a new file upgrade_ha.sh, make it executable with chmod +x upgrade_ha.sh
and runt it via shell_command
Are you confident with this approach? I think you should always read the release note before upgrade with closed eyes…
Perfect. I’ll try. Thank you
These are commands to install homeassistant in a python venv.
For upgrade you only need to:
source bin/activate
pip install --upgrade homeassistant
Not needed:
as the script alraedy runs as the homeassistant user when started from a shell_command
and as the venv is already created
python3.8 -m venv .
I tried various things but I keep getting this error
Logger: homeassistant.components.shell_command
Source: /srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/shell_command/__init__.py:114
Integration: Shell Command (documentation, issues)
First occurred: 20:31:11 (1 occurrences)
Last logged: 20:31:11
Error running command: `chmod +x /home/homeassistant/.homeassistant/script/upgrade_ha.sh`, return code: 1
NoneType: None
I don’t know if it’s a permission problem.
To be safe apply all 777 permissions and configure pi: homeassistant as user and group
Change the folder user to homeassistant: homeassistant and now there is no error but it does not update and does not restart either.
the script
source bin/activate
/usr/bin/sudo /bin/systemctl restart home-assistant@homeassistant
Hello. I still can’t run the script correctly
Error running command: `/usr/bin/sudo sh /home/homeassistant/.homeassistant/script/upgrade_ha.sh`, return code: 1
It tells me this error.
But still I can’t run the bash properly.
When it is executing the bash it says source not found
/usr/bin/sudo /bin/systemctl stop home-assistant@homeassistant
source bin/activate
/srv/homeassistant/bin/python3.8 -m pip install --upgrade pip
Pablo_Gustavo_Fiscel:
source not found
Try it with:
. bin/activate
OR
add the bash shebang on top of your script
#!/bin/bash
chmod a+x /home/homeassistant/.homeassistant/script/upgrade_ha.sh
and remove
/usr/bin/sudo sh
from your HA shell_command
BTW: If the script is called from HA, i don’t think it’s a good idea to stop HA in the script. Not sure, but i think running scripts are canceled when HA stops.
And like dapuzz said:
If something went wrong with the update, your HA will not restart.
I always update my instance manualy in a terminal to see the logs.
From what I understand this folder should be after home assistant is working.
So put the script in this folder. If I run it by console it works but I have to execute it like this: sh upgrade_ha.sh
Console (here script executable)
(homeassistant) homeassistant@raspberrypi:/srv/homeassistant $
Script
#!/bin/bash
. bin/activate
pip3 install --upgrade homeassistant
shell_command: upgrade_ha.sh
and
Error
First occurred: 15:02:05 (1 occurrences)
Last logged: 15:02:05
Error running command: `upgrade_ha.sh`, return code: 127
NoneType: None
Works.
The problem was some lines of the bash.
I started with the empty bash file to rule out the problem and started adding de to a command.
Bash File
#!/bin/bash
. bin/activate
ShellCommand
ha_update: /home/homeassistant/.homeassistant/script/upgrade_ha.sh
@dapuzz @VDRainer thank you very much
You don’t need to source activate if you just run pip3 with the full path. Try to use full paths whenever using a script for safety/security. You can likely just use the following as a shellcommand
/srv/homeassistant/bin/pip3 install --upgrade homeassistant
