Automation using clickAction as a trigger
Hello everyone,
I get a notification when someone rings the doorbell:
service: notify.notify
  title: Alguém tocou à campainha!
    timeout: 180
    priority: high
    ttl: 0
    clickAction: /lovelace/campainha
    tag: campainha
    image: >-
      https://example.ddns.com/local/doorpi/doorbell-image.jpg?{{now().second}}
  message: ''
And I want to create an automation to clear the notification on all devices when some of the users click on the notification (using clickAction). What is the trigger for automation? Or can I have a clickAction with two actions (one for opening the application and one for a boolean variable)?
Thank you everyone!
Best regards
Gonçalo Almeida
clickAction only controls what view or app is opened when its selected, there is no specific event sent back to HA. You can try to see if the notification clear event gets fired but that will be your easiest indication to clear the notification.
You can also try to see if the notification shows up in the active notification count and then clear based on it not being present.
With “mobile_app_notification_cleared” only works if notification is cleared if I open it don’t clean it on all devices…
alias: Clean Doorbell Notification
description: ''
  - platform: event
    event_type: mobile_app_notification_cleared
    event_data:
      tag: campainha
condition: []
  - service: notify.notify
        tag: campainha
      message: clear_notification
mode: single
Can you help me with active notification count?
Best regards
