I’ve been triggering a bunch of lighting automations using input_selects, and they’ve recently stopped working. I can’t be sure when, but it happened prior to 0.49.0 (I’m on .1 now). I can’t for the life of me see where I’ve gone wrong.
I have my config broken out into lots of files, so you’ll have to take my word for it that my yaml is sound. I certainly get the all clear when I run hass with check_config.
Ponder the following automation:
alias: 'Front room: bright'
platform: state
entity_id: input_select.front_room_scenes
to: 'Full brightness'
- service: scene.turn_on
entity_id: scene.front_room_bright
- service: input_select.select_option
option: Full brightness
Pretty straightforward, right? When a particular input_select is set to the option “Full brightness”, it triggers. First action is to turn on a specific scene, and the second is to set that very same input_select to the selected option. The reason I do the second action is because I have Google Assistant triggering the same automation via the API (using IFTTT).
Here’s the corresponding input_select:
front_room_scenes:
options:
- Full brightness
- Watching TV
- Lights off
initial: Lights off
icon: mdi:lightbulb
And here’s the scene:
- name: front_room_bright
entities:
group.front_room_lamps:
state: on
brightness: 254
If I turn on the scene manually, it works. If I call the automation manually, it works. The input_select, however, has stopped working. It doesn’t matter if I call it from the dropdown in the hass interface, or test it via the API - it doesn’t do anything. When I turn up my logging to debug, I don’t seem to get anything useful - it simply logs the option change.
Have I missed a functionality change in a recent update? I’m tearing my hair out on this one!
