I am trying to capture the “MESSAGE” element of the SYSTEM_LOG_ERROR when an error is found in the log and input this into the message body of an email as below;
alias: 'Notify Error in Hassio Log'
platform: event
event_type: system_log_event
event_data:
level: ERROR
- service: notify.notifier_name
data_template:
message: Error in Hassio Log found
title: Madden - Home Assistant Server
- service: notify.send_email
title: Hassio Error Log Found
message: '{{ trigger.event.data.message }}'
The problem I am seeing is the last line I get this error;
Error while executing automation automation.notify_error_in_hassio_log. Error rendering template for call_service at pos 2: UndefinedError: 'trigger' is undefined
I don’t mean to hijack your post but when I paste the exact same code you provided and I manually fire an event, it shows on the console but the automation is not triggered.
Here is my code:
- alias: Create notifications for all errors
platform: event
event_data:
level: ERROR
service: persistent_notification.create
data_template:
title: Something bad happened
message: "{{ trigger.event.data.message }}"
Then I manually fire this event through the developer tools :
message: Something went wrong
level: error
logger: mycomponent.myplatform
It shows in the console but the automation is not triggered and does not output any error either.
2021-02-08 10:41:07 ERROR (MainThread) [mycomponent.myplatform] Something went wrong
Any help or input would be greatly appreciated. Thanks
