Hi Andre,
Does your sensor.humidade_wc_last_hr.attributes.mean works ? when you use the developper tool do you have a value using
{{ states('sensor.humidade_wc_last_hr.attributes.mean') | float}}
Cause this should work
Hi Andre,
Hello budcalloway,
Actually in developer tools I’m not getting data.
How can I use this atribute value in Automation?
What do you have in the “States” tab ?
You have the format mixed up… either of these two will work (the top one is preferred):
{{ state_attr(‘sensor.humidade_wc_last_hr’, ‘mean’) | float(0) }}
{{ states.sensor.humidade_wc_last_hr.attributes.mean | float(0) }}
Hello Didgeridrew,
Thanks a lot for the help.
Now I’m struggling to make the automation work.
I intent to use Automation Template Trigger with two sensors like this:
{% if state_attr('sensor.humidade_wc_last_hr', 'mean') | float(0) < states('sensor.bme_3_relative_humidity') | float(0) %}true{% endif %}
But it seems that is not actually working, in dev tool-template, this is what I get:
Your template is working correctly. The template is false and you did not tell it what to do in that case, so it returned nothing…
For a your purposes you don’t need an if statement… all you should need is:
{{ state_attr('sensor.humidade_wc_last_hr', 'mean') | float(0) < states('sensor.bme_3_relative_humidity') | float(0) }}
Thanks a lot Didgeridrew.
It’s finally working.
So now if the mean humidity of last 2 hours (plus 10%) is less that actual humidify it will trigger the VMC to level 3.
- id: '1637154302262'
alias: WC - Humidade VMC nível 3
description: se humidade atual acima humidade média+10%, vmc nível 3
value_template: '{{ state_attr('sensor.humidade_wc_last_hr', 'mean')
| float(0) * 1.1 < states('sensor.bme_3_relative_humidity') | float(0) }}'
condition: []
- service: mqtt.publish
topic: ventilation/ventset
payload: '3'
qos: '2'
- service: notify.mobile_app_mi_a2
ttl: 0
priority: high
message: WC Hum VMC n3
mode: single
Hello again Didgeridrew,
This is a little bit off topic, but maybe you can guide me on how to create a sensor to get the value of 24hr ago.
Tks
Hi everyone!
Can someone help me with the templates below?
Both value templates give me an error when I test them.
This is the error I get:
- choose:
- conditions:
- condition: template
value_template: >-
{{ states('sensor.multisensor_basement_humidity') | float >
states('input_number.basement_max_humidity') | float }}
sequence:
- service: humidifier.set_mode
mode: Dry
entity_id: humidifier.dehumidifier_bsmnt
- conditions:
value_template: >-
{{ states('sensor.multisensor_basement_humidity') | float <=
I don’t understand what is wrong with the templates. Anyone sees the mistake?
Thank you!
Your float
filters will need defaults. However, the error is due to the fact that the UI condition tester in the automation editior does not currently work for Template conditions.
Didgeridrew is right.
I’d add that if you want to test your templates, do it in the dev tools
