Automation using trigger.from_state
Hi, I am trying to collect charging data as it changes, and I need to get the difference between the old and new values, so I modifies a suggestion by petro
However I cannot get it to work, and after blundering around in Yaml I am pleading for help.
My automation is
alias: Test trigger from
description: ""
  - platform: state
    entity_id:
      - input_number.ezri_charge_added_session
variables:
  continue: >
    {{ trigger | default(none) is not none and trigger.to_state is defined and trigger.from_state is defined }}
  before: >
    {{ trigger.from_state.state | float(0) if continue else 0 }}
  after: >
    {{ trigger.to_state.state | float(0) if continue else 0 }}
  result: >
    {{ input_number.ezri_charge_added_today + after - before }}
condition:
- condition: template
  value_template: "{{ continue }}"
  - service: input_number.set_value
      value: result
      entity_id: input_number.ezri_charge_added_today
mode: single
that fails with
Stopped because of unknown reason “null” at September 28, 2023 at 9:03:20 AM (runtime: 0.00 seconds)
and strangely the automation is modified putting the variables down the bottom as below
description: ""
  - platform: state
    entity_id:
condition:
      value: result
variables:
  continue: >
  before: |
  after: |
  result: |
mode: single
Any help would be wonderful, thanks in advance
Change this:
  result: >
to this:
  result: >
    {{ states('input_number.ezri_charge_added_today') | float(0) + after - before }}
Change this:
      value: result
to this:
      value: '{{ result }}'
It doesn’t matter.
Thank you - obvious when you put it like that!
Thanks again, works perfectly
