I have an automation wich turns on some lights, if I enter the flat. (There is an other automation for triggering the lights inside the flat. Different lights)
As “IF” I have
a presense sensor (FP2)
a normal PIR sensor assuming the “if part” is an “OR-Condition”, isnt it ?
Before I changed my automation (by adding the presense sensor), there was only a PIR sensor, but sometimes the cats triggered the sensor and it was not working.
As Condition I have a door sensor. (Homematic)
With only the PIR sensor, the door sensor was faster than the PIR sensor and the automation was working.
Now sometimes the Presense sensor is faster than the door sensor. Is there a way to add a kind of “waiting” for the other sensor ? 1-2 seconds are enough. Difficult to explain. ^^
At the moment it is:
Movement / Presence detected AND Door is already open → Light on
I need this: Movement / Presence detected AND Door is already open OR will be opened in 1-2 seconds → Light on
I can not change the order (IF and CONDITION), because if I leave the flat and open the door, it will turn on the light because there is already presense detected.
What’s binary_sensor.eingangstur? Is it the occupancy or motion sensor?
Is it part of one of the two Device Triggers? We can’t tell from your example because a Device Trigger’s entity_id is an alphanumeric identifier.
Probably because the condition requires binary_sensor.eingangstur to be on and then the wait_for_trigger requires it to change to on (but it’s already on). So it simply times out after 2 seconds. It continues to the next action because that’s the default behavior after a timeout.
I want this:
door open (before motion) and motion detected → light on
motion detect 1st and door open inside 2 seconds after motion was detected → light on
For the search function, now its working.
The solution was to remove the door sensor from the condition part.
After this, I added the sensor again from the GUI with the type “opened” and continue_on_timeout: false
The code in the condition part is only a switch in the dashboard to disable the automation. The 2nd trigger is removed, because it is not longer needed.
alias: "Bewegungsmelder: Flur bei Tür auf automatisch EIN"
description: ""
- type: occupied
platform: device
device_id: 572f2f1551d0181ca79a3994ee622fee
entity_id: 9d5ff28aafc158c7f25d11819c6c6e8c
domain: binary_sensor
condition:
- condition: state
entity_id: input_boolean.lichtbeiturautomatischein
state: "on"
- wait_for_trigger:
- type: opened
platform: device
device_id: 3596d0ee60eaa1551362574b6273c442
entity_id: 96b47b19b21d2d65e987c35b3d8bea84
timeout:
seconds: 2
- type: turn_on
device_id: dcbf8fb07a86922e8e7d045b433ae667
entity_id: a25d838198b4fef8a741a9cc418c7575
domain: light
- service: notify.alexa_media_wc_dot
metadata: {}
message: Hallo Boss und Hallo Bossine. Willkommen zu Hause.
mode: single
