I’m trying to create an automation that will notify me when the current temp reaches the target temp from a climate entity. Not sure how to get it to trigger? (Use-case: I have a Traeger integration that uses a climate entity for the probe and wanting to announce on my speakers when the probe reaches temp)
The use of the float filter in this particular case may not be necessary. The values being compared may already be floating point numbers and not strings.
I suggest you mark finity’s post with the Solution tag because it was the first to offer the correct suggestion. My post merely corrected a template syntax error.
