I would like to see if its possible to setup an automation to trigger when the door is open and the amplifier is switched on. If this condition is met then i must set the amplifier volume level in a variable and then set the volume to -70dbm. Then when the door is closed again the volume should be restored to its previous volume level which was stored in the variable.
Any ideas how i can go about it.
Thanks,
Et
