Automation which runs on the 1st of december every year?
I’m trying to create an automation which is supposed to run on a specific date, every year. For example at the 1st of december every year. I’m not sure which is the easiest way to go about that.
For fun I tried asking ChatGPT and it came up with a solution which uses a trigger with a platform of ‘yearly’ which looked promising but then Home Assistant warns that it’s an invalid platform.
How would you go about this?
The new local calendar integration (or any other integratable calendar) should be able to help you with this :slight_smile:
Bingo. That’s a neat way to do this. I think I’ve successfully managed to do it.
