tomasr
(Tomas)
December 4, 2024, 6:40pm
1
How can I make an automation with a time trigger based on the state of another entity.
Unfortunately, it doesn’t work this way, whether the time is in quotes or not.
alias: Switch on
description: ""
value_template: |-
{% if state_attr('input_boolean.is_specific_time', 'on') %}
16:00:00
{% else %}
18:00:00
{% endif %}
condition:
- condition: state
entity_id: input_boolean.is_time
state: "on"
- type: turn_on
device_id: 9060d45c25d64a300c351549a3887ac7
entity_id: switch.tuya_power_strip_switch4
domain: switch
mode: single
There are a few issues…
Time triggers do not accept templates, but you aren’t using one anyway…
A Template trigger only fires when the value it returns changes from “false” to “true”. Assuming you fixed the if statement, the template you have used will still never return “true”… only “16:00:00” or “18:00:00”, both of which count as false.
Here’s one way to make it work:
alias: Switch on
description: ""
- platform: time
at:
- "16:00:00"
- "18:00:00"
condition:
- condition: template
value_template: |
{% if is_state('input_boolean.is_specific_time', 'on') %}
{{ trigger.now.hour == 16 }}
{% else %}
{{ trigger.now.hour == 18 }}
{% endif %}
- condition: state
state: "on"
- type: turn_on
domain: switch
mode: single
tomasr
(Tomas)
December 4, 2024, 10:34pm
3
It looks great, I will test it.
Thank you:)
