Hello together,
I need your help again ;(
We have now installed a heat pump and to optimize the hot water behavior, we have now found that a temperature in the hot water tank of 43 ° C is sufficient to shower.
Unless my wife wants to use the bathtub, then the hot water must be heated to 50°C.
To make it as easy as possible for her, I would like to integrate a button in the HA dashboard that makes all the clicks in the menu unnecessary.
My idea:
- Input Button Dashboard
( input_boolean.take_bath ) - When the button is pressed:
– Set the target temperature for the WW storage tank to 50°C.
( number.panasonic_heat_pump_main_dhw_target_temp )
– Change mode from “Heat only” to “Heat + DHW”.
( select.panasonic_heat_pump_main_operating_mode_state ) - When the target temperature of 50°C has been reached, undo the changes.
( sensor.panasonic_heat_pump_main_dhw_temp )
Has anyone possibly done something similar and could share their solution so I have an idea how to start?
Haven’t done anything with the automations yet unfortunately ;(
Thanks.
