Hi, I would like to set the brightness and colour of my light depending on time of day.
Since both values require the same if then else statement I was hoping I could do it in 1. Is that possible?
This works:
- alias: Ensuite Light by motion ON
initial_state: 'on'
- platform: state
entity_id: binary_sensor.motion_sensor_158d00016570dc
to: 'on'
service: homeassistant.turn_on
entity_id: light.ensuite_light
data_template:
brightness: >
{% if states.sensor.time_of_day.state == "night" %} 80
{% elif states.sensor.time_of_day.state == "late evening" %} 150
{% else %} 255
{% endif %}
color_name: >
{% if states.sensor.time_of_day.state == "night" %} green
{% elif states.sensor.time_of_day.state == "late evening" %} blue
{% else %} white
{% endif %}
but I would like to have something like this:
initial_state: 'on'
- platform: state
to: 'on'
data_template:
brightness: 80
color_name: blue
brightness: 150
color_name: green
{% else %}
brightness: 255
color_name: white
{% endif %}
in the dev console it looks OK, but there are no examples that would support that this should work.
Is it possible?
AFAIK you have to do it the way you have it in the first one because the template spits out a string, not formatted keys (for want of a better way to explain it).
you could also create a scene per desired situation. scene.night, scene.late_evening, scene.default.
Which I always find easier to maintain, since youâd not need to change the automation, but only the scene whenever you want to change the end-effect. Keeping the logic and the content apart. Safe and simple.
this is what I use, nothing special.
Though when hassio updates start to fall apart and stop supporting rgb color settings like this, which seems to have happened reading all comments after 66 came along, it is easier to change only the scene, and not have to dive into the automationâŚ
- name: Opstart
entities:
light.kist:
state: on
transition: 4
brightness: 199
# color_temp: 153
rgb_color: [255,93,42]
- name: Naar bed
entities:
light.bedside_table:
state: on
transition: 4
brightness: 37
# color_temp: 153
rgb_color: [171,58,22]
- name: Opstaan
entities:
light.kist:
state: on
transition: 4
brightness: 199
# color_temp: 153
- name: Gym
entities:
light.kist:
state: on
transition: 4
brightness: 199
# color_temp: 153
- name: Selamat makan
entities:
light.dining_table_lamp_1:
state: on
transition: 4
brightness: 206
color_temp: 443
light.dining_table_lamp_2:
state: on
transition: 4
brightness: 206
color_temp: 443
light.dining_table_lamp_3:
state: on
transition: 4
brightness: 206
color_temp: 443
- name: Aan de slag
entities:
light.bureau:
state: on
transition: 4
brightness: 233
color_temp: 370
light.inside:
state: on
transition: 4
brightness: 127
# color_temp: 370
rgb_color: [218,176,100]
light.outside:
state: on
transition: 4
brightness: 127
# color_temp: 397
rgb_color: [222,174,91]
- name: Uit huis
entities:
light.kist:
state: on
transition: 4
brightness: 199
# color_temp: 153
That sounds like to proper solution.
But that would mean 1 scene per time-period per room?
It looks like scenes do not support data-templates (yet)?
I will need to think about this option. It is a bit of a change from the current setup.
Also this statement in the documentation means I then need to maintain the list of entities in the scene also in the automation to turn all entities off.
Scenes can be activated using the service scene.turn_on (there is no âscene.turn_offâ service).
But thanks for the input. I will investigate further.
What @Mariusthvdb is saying is that you use a script/scene to pass variables to. But I think youâll have the same issue that we have above. I think a good enhancement to hass would be to have the template parser handle lists and dictionaries. It wouldnât be too hard to implement IMO.
Anyways, for now it looks like youâll need 2x the logic or a script for each âif branchâ.
