Automation with device tracker home/away only working for home, not when away
I have two automations. One is to switch on two lights when device_tracker.e4_46_da_73_3d_94 is home, the other is to switch the same two lights off when device_tracker.e4_46_da_73_3d_94 is away.
It is registered (as per logbook), that device_tracker.e4_46_da_73_3d_94 is home or away.
And when home is registered, the automation runs and the two lights are switched on.
However, the away part is not working. It is registered fine as per logbook that device_tracker.e4_46_da_73_3d_94 is away, but the automation is not triggered.
How can that be? I have tried other combinations with the state from home to away, capital letters, etc. But no luck. I just do not see what are the differences between the two automations?
- id: '1595725165750'
  alias: light_gang_on
  description: ''
  - entity_id: device_tracker.e4_46_da_73_3d_94
    platform: state
    to: home
  condition: []
  - device_id: c67be167c7a7458fb2553e424313bff0
    domain: light
    entity_id: light.gang_1
    type: turn_on
  - device_id: 5ceec93fd3414b68b1c88aef5b9ebc74
    domain: light
    entity_id: light.gang_2
    type: turn_on
  mode: single
- id: '1596634386395'
  alias: light_gang_off
  description: ''
    platform: state
    to: away
  condition: []
    domain: light
    type: turn_off
    domain: light
    type: turn_off
  mode: single
