passie
(passie)
April 27, 2017, 1:52pm
1
I have the following sensor sending the temp over mqtt to the broker which runs on the same pi as HA.
platform: mqtt
state_topic: “ha/in”
unit_of_measurement: “C”
value_template: ‘{{ value_json.svalue }}’
I would like to change the color of the leds by automating it within HA if the temperature rises above 15c.
Though i’m unable to get this right.
alias: Above 15
platform: state
entity_id: sensor.esp0
condition:
- condition: template
value_template: ‘{{ value_json.svalue < 15 }}’
service: shell_command.set_candle_above
shell_command:
set_candle_above: ‘curl --data “cmd=CANDLE:3:FF0000:200” http://192.168.0.14/control ’
I’m getting the following error:
17-04-27 16:06:20 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: ‘value_json’ is undefined
What am i doing wrong ?
As the error says, ‘value_json’ is not available in the automation.
You have to work with your sensor, so
value_template: '{{ states.sensor.esp0.state | int < 15 }}'
should work.
ih8gates
(Scott Reston)
April 27, 2017, 2:17pm
3
You’ll want to look at the state of sensor.esp0 and use a numeric trigger. Something like this should work:
platform: numeric_state
above: 15
passie
(passie)
April 27, 2017, 4:15pm
4
Thank you both.
I’m getting close since i’m not getting any errors now , though it’s not executing the shell_command.
While data is coming in true the mqtt
{“idx”:123,“nvalue”:0,“svalue”:“21.06”}
I tried
value_template: ‘{{ states.sensor.esp0.state }}’
and
value_template: ‘{{ states.sensor.esp0.state > 15 }}’
getting the following message in logbook.
Above 15 turned on
When i press Above 15 I can trigger it manually. this works.
Any clue points here ?
keithh666
(Keith Hull)
April 27, 2017, 7:58pm
5
I would try it without the double quotes in the shell command or maybe put | int as the value is a float.
passie
(passie)
April 28, 2017, 2:36pm
6
This is what I have now.
- alias: red
above: 20
- alias: green
below: 20
service: shell_command.set_candle_below
But still not working.
Would be nice if I could debug the triggers somehow.
The ‘svalue’ in the mqtt json payload is a string.
So you can convert it in your sensor
value_template: '{{ value_json.svalue | int }}'
(float should already work)
and use the numeric_state trigger, or you use the template trigger as i suggested in my first post.
passie
(passie)
April 28, 2017, 3:11pm
8
I already have the value_template converted to a int
like
- platform: mqtt
state_topic: "ha/in"
unit_of_measurement: "°C"
I don’t understand the part where you say I could use a template trigger.
If you mean like using it like this:
- alias: red
platform: state
condition:
value_template: '{{ value_json.svalue | int < 15 }}'
it’s not working either
If your sensor returns a number, you can use the numeric_state trigger.
- alias: red
above: 20
If it returns a string, you can convert the sensor value to a number, or you can use the template trigger
- alias: red
platform: template
Both will only trigger if the value changes. Maybe this is your problem.
passie
(passie)
April 28, 2017, 4:06pm
10
Finally it’s working. Sorry for not understanding the first time.
I’m using the second option you posted.
- alias: green
platform: template
value_template: '{{ states.sensor.esp0.state | int < 23 }}'
- alias: red
platform: template
value_template: '{{ states.sensor.esp0.state | int > 23 }}'
Thank you
