I tried the new for_each and if feature in an automation but always get an error
Can someone point me in the right direction?
Here is the automation:
- id: 'sunprotection'
alias: Sun Protection
description: ''
- platform: state
entity_id:
- input_button.sunprotection
condition: []
- repeat:
for_each:
- sensor: binary_sensor.room1
cover: cover.room1
message: Room1
- sensor: binary_sensor.room2
cover: cover.room2
message: Room2
sequence:
- if:
- condition: state
entity_id: {{ repeat.item.sensor }}
state: 'off'
then:
- service: cover.close_cover
data: {}
entity_id: {{ repeat.item.cover }}
else:
- service: notify.mobile_app_xxx
message: "Cover in {{ repeat.item.message }} cannot be closed!"
But when I do a config-check, I always get the error:
Error loading /config/configuration.yaml: invalid key: "OrderedDict([('repeat.item.sensor', None)])"
in "/config/automations.yaml", line 937, column 0
Thanks a lot in advance
Joerg
Did you figure this out @derjoerg ? I want to do something similar and having trouble finding the syntax.
Change to
- repeat:
for_each:
cover: cover.room1
message: Room1
cover: cover.room2
message: Room2
See, docs , for_each
is a child of repeat
not a sibling.
@CentralCommand Thank you! Do you know if you can define a list in variables
to use in a for_each
loop?
Yes. for_each
takes a template and templates can return a list. So if you have a variable with a list you just do this:
- repeat:
for_each: "{{ my_list }}"
sequence:
Thank you @CentralCommand ! I was able to contribute a change to the shellies gen2 script thanks to your help! https://github.com/bieniu/ha-shellies-discovery-gen2
derjoerg
(Joerg)
July 25, 2022, 11:57am
7
Thanks a lot that did the trick for this. But now the next problem
description: ''
mode: single
- platform: state
entity_id:
- input_button.sun_protection
condition: []
- repeat:
for_each:
- window: binary_sensor.room1
cover: cover.room1
message: Room1
position: 0
- window: binary_sensor.room2
cover: cover.room2
message: Room2
position: 25
sequence:
- if:
- condition: state
entity_id: "{{ repeat.item.window }}"
state: 'off'
then:
- service: cover.set_cover_position
position: "{{ repeat.item.position }}"
entity_id: "{{ repeat.item.cover }}"
else:
- service: notify.mobile_app_xyz
Message malformed: Entity {{ repeat.item.window }} is neither a valid entity ID nor a valid UUID for dictionary value @ data['action'][0]['repeat']['sequence'][0]['if'][0]['entity_id']
Can it be that I can’t use variables “{{ }}” within an if-condition?
You can. But not here:
Not all fields accept templates, some only allow constants. The entity_id
field in conditions and triggers is one such field. Although it does accept templates in service calls (which admittedly is a little confusing).
Anyway you have to do your condition like this:
if:
condition: template
value_template: "{{ is_state(repeat.item.window, 'off') }}"
Or just this for the shorthand form:
if: "{{ is_state(repeat.item.window, 'off') }}"
NamCisum
(Daniel)
November 26, 2022, 7:33pm
9
I am getting the same error as above, but in an imo pretty simple setting:
- alias: 'Z-Wave Roller Shutter Fix Missing Power Update'
- platform: numeric_state
entity_id: sensor.leistung_beschattung
above: 0
for: 00:05:00
- repeat:
for_each:
- sensor.raff_arbeiten_links_electric_consumption_w
- sensor.raff_arbeiten_rechts_electric_consumption_w
- sensor.raff_essen_links_electric_consumption_w
- sensor.raff_essen_mitte_links_electric_consumption_w
- sensor.raff_essen_mitte_rechts_electric_consumption_w
- sensor.raff_essen_rechts_electric_consumption_w
- sensor.raff_kuche_fenster_electric_consumption_w
- sensor.raff_kuche_tur_electric_consumption_w
- sensor.raff_wohnzimmer_mitte_links_electric_consumption_w
- sensor.raff_wohnzimmer_mitte_rechts_electric_consumption_w
- sensor.raff_wohnzimmer_tur_links_electric_consumption_w
- sensor.raff_ug_wohnen_links_electric_consumption_w
- sensor.raff_ug_wohnen_rechts_electric_consumption_w
- sensor.raff_ug_wohnen_tur_links_electric_consumption_w
- sensor.raff_ug_wohnen_tur_rechts_electric_consumption_w
- sensor.roll_ankleide_electric_consumption_w
- sensor.roll_bad_dach_electric_consumption_w
- sensor.roll_bad_tur_electric_consumption_w
- sensor.roll_eingang_fenster_electric_consumption_w
- sensor.roll_eltern_dach_electric_consumption_w
- sensor.roll_eltern_tur_electric_consumption_w
- sensor.roll_gaste_wc_electric_consumption_w
- sensor.roll_hannah_dach_electric_consumption_w
- sensor.roll_hannah_tur_electric_consumption_w
- sensor.roll_hwr_electric_consumption_w
- sensor.roll_linus_dach_electric_consumption_w
- sensor.roll_linus_tur_electric_consumption_w
- sensor.roll_treppe_dach_electric_consumption_w
- sensor.roll_ug_bad_electric_consumption_w
- sensor.roll_ug_arbeiten_electric_consumption_w
- sensor.roll_ug_schlafen_electric_consumption_w
sequence:
- condition: numeric_state
entity_id: "{{ repeat.item }}"
above: 0
- service: zwave_js.refresh_value
refresh_all_values: false
- delay: 00:00:02
- service: notify.rsfix
message: >
{{ state_attr( repeat.item , 'friendly_name') }} wurde abgefragt, neuer Wert: {{ (states( repeat.item ) | float) | round(0) }}
Error:
2022-11-26 20:25:49.731 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Entity {{ repeat.item }} is neither a valid entity ID nor a valid UUID for dictionary value @ data['action'][0]['repeat']['sequence'][0]['entity_id']. Got None. (See /config/configuration.yaml, line 37).
I thought I followed the docs and the examples above to the point (just not naming the items for the loop as it’s only one entity to be iterated over). I also understood that using sequence in automations is possible now.
Probably a pretty simple mistake on my side, after checking for an hour I just can’t find it…
UPDATE: Dammit, the answer is in the post just above! It’s not possible to use a template in a condition (I thought that did not apply to a condition inside a sequence, just the condition part of the automation). If I use template: condition
I do not get an error
The entity_id
field of conditions does not support templates. So this
Won’t work. You have to use a template type condition instead. Or use a template to filter those entities out of the list in the for_each
step before beginning the loop.
Not all fields support templates. entity_id
fields in particular rarely do. The exception is in service calls but that’s not one of those.
NamCisum
(Daniel)
November 26, 2022, 7:49pm
11
Thank you Mike for the quick response - I figured the same after re-reading your last response. This does not throw an error:
sequence:
- condition: template
value_template: "{{ (states( repeat.item ) | float) > 0 }}"
