Hi there,
i´m new to HA and i installed HASS.IO on my Pi3.
Unfortunately i´m not a gifted Guy when it comes to coding, but at least i try
I want to setup an Input select für my Radio. Its a second Pi with RuneAudio on it and i want to control it with HTTP.
So i setup the Shell commands in my configuration.yaml
play: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=play"
stop: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=stop"
lauter: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=volume +2"
leiser: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=volume -2"
clear: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=clear"
abay: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=load AntenneBayern"
rocka: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=load RockAntenne"
bay1: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=load Bayern1"
bay3: curl --silent -k "http://runeaudio.hoff.lan/command/?cmd=load Bayern3"
Each command is tested and it works.
Later i started to create the scripts in the scripts.yaml:
play:
sequence:
- service: shell_command.play
stop:
sequence:
- service: shell_command.stop
And so on…
I tested the script in the “services” with
Service: script.turn_on
{"entity_id":"script.play"}
And this is my automation.yaml
- action:
- service: script.turn_on
entity_id: >
{% if is_state("input_select.radio", "Antenne Bayern") %}
script.abay
{%-elif is_state("input_select.radio", "Rock Antenne") %}
script.rocka
{%-elif is_state("input_select.radio", "Bayern 1") %}
script.bay1
{%-elif is_state("input_select.radio", "Bayern 3") %}
script.bay3
{%-elif is_state("input_select.radio", "Radio ausschalten") %}
script.stop
{%-elif is_state("input_select.radio", "Reboot") %}
script.reboot
{% else %}
none
{% endif %}
- service: input_select.select_option
entity_id : input_select.radio
option: Wähle einen Radiosender
alias: Radiosender
hide_entity: true
- entity_id: input_select.radio
platform: state
The Input select should load the playlist at Runeaudio at first. After this is successful i will add the “play” in the sequence.
The Config Check will say there is an Error but there is no hint whats the problem. The YAML Check is also fine. But when i hit the input this entry will appear in my Log:
ERROR (MainThread) [homeassistant.core] Invalid service data for script.turn_on: Entity ID {% if is_state("input_select.radio" is an invalid entity id for dictionary value @ data['entity_id']. Got '{% if is_state("input_select.radio", "Antenne Bayern") %}\n script.abay\n {%-elif is_state("input_select.radio", "Rock Antenne") %}\n script.rocka\n {%-elif is_state("input_select.radio", "Bayern 1") %}\n script.bay1\n {%-elif is_state("input_select.radio", "Bayern 3") %}\n script.bay3\n {%-elif is_state("input_select.radio", "Radio ausschalten") %}\n script.stop\n {%-elif is_state("input_select.radio", "Reboot") %}\n script.reboot\n
Best regards and greetings from Germany
Thank you so much.
