vormsty
(Vormsty)
November 2, 2020, 7:27pm
1
Hello, I want to improve the behaviour of thermostats.
For that, I will start the heating earlier if the temperature is below one of couple time / temp.
For exemple I will start the heater if:
at 6h30 the temperature is below 18.8 or
at 5h30 if the temperature is below 17,7 or
I don’t know how to write the automation…
Many thanks for your help !
Best regards
apmillen
(Andy)
November 3, 2020, 10:32am
2
Try something like this.
- platform: time
at: '05:30:00'
condition:
- condition: state
entity_id: sensor.temperature
below: 17.7
- service: climate.set_temperature
entity_id: climate.thermostat
temperature: 20.0
hvac_mode: heat
and then add another one for 6:30 at 18.8
vormsty
(Vormsty)
November 3, 2020, 2:48pm
3
Thanks for your reply.
I have one automation per file.
I do what you explain me with your post.
But, with this technique, I will have one file for each point, so a lot of different file.
I would like to have for one thermostat all points
Thanks.
apmillen
(Andy)
November 3, 2020, 5:26pm
4
There is a way by using trigger.now
I’m not at the computer at the moment but there is more info here:
I can try and explain a bit more later
123
(Taras)
November 3, 2020, 6:00pm
5
Simply create a file containing multiple automations.
Sometimes it’s much simpler to create and maintain multiple short and simple automations rather than attempt to consolidate it into a single long and complex automation.
Each short automation can call a script and pass it the desired temperature.
- alias: 'Scheduled Temperature 05:30'
- platform: time
at: '05:30:00'
condition:
- condition: state
below: 17.7
- service: script.setpoint_temperature
setpoint: 20
- alias: 'Scheduled Temperature 06:30'
- platform: time
at: '06:30:00'
condition:
- condition: state
below: 18.8
setpoint: 22
The script sets the thermostat at the desired setpoint temperature:
#script:
setpoint_temperature:
sequence:
temperature: '{{setpoint}}'
hvac_mode: heat
EDIT
If you really want to consolidate it into a single automation, here’s one possible way to do it:
- alias: 'Scheduled Temperature'
- platform: time
at:
- '05:30:00'
- '06:30:00'
choose:
- conditions: "{{(trigger.now.time()|string)[:5] == '05:30' and states('sensor.temperature') < 17.7 }}"
sequence:
setpoint: 20
- conditions: "{{(trigger.now.time()|string)[:5] == '06:30' and states('sensor.temperature') < 18.8 }}"
sequence:
setpoint: 22
If you don’t like this:
you can replace it with:
trigger.now.hour == 5 and trigger.now.minute == 30
vormsty
(Vormsty)
November 5, 2020, 1:15am
6
Sorry, I never see you comment.
Many thanks for your help.
A question:
what does means: string)[:5] ?
Thanks a lot ! I never see conditions in the action part !
123
(Taras)
November 5, 2020, 1:33am
7
It’s python’s slice notation. It’s extracting the first 5 characters from the string containing the time.
The time is presented like this:
21:45:00
and we only need the first five characters containing the hours and minutes.
The Python string data type is a sequence made up of one or more individual characters consisting of letters, numbers, whitespace characters, or symbols. Str…
They are part of choose
. For more information about choose
, refer to the documentation:
Choose a group of actions
