Automation with many couple of time and temperature condition
Hello, I want to improve the behaviour of thermostats.
For that, I will start the heating earlier if the temperature is below one of couple time / temp.
For exemple I will start the heater if:
at 6h30 the temperature is below 18.8 or
at 5h30 if the temperature is below 17,7 or
I don’t know how to write the automation…
Many thanks for your help !
Best regards
Try something like this.
  - platform: time
    at: '05:30:00'
  - condition: state
    entity_id: sensor.temperature
    below: 17.7
  - service: climate.set_temperature
     entity_id: climate.thermostat
     temperature: 20.0
     hvac_mode: heat
and then add another one for 6:30 at 18.8
Thanks for your reply.
I have one automation per file.
I do what you explain me with your post.
But, with this technique, I will have one file for each point, so a lot of different file.
I would like to have for one thermostat all points
Thanks.
There is a way by using trigger.now
I’m not at the computer at the moment but there is more info here:
I can try and explain a bit more later
Simply create a file containing multiple automations.
Sometimes it’s much simpler to create and maintain multiple short and simple automations rather than attempt to consolidate it into a single long and complex automation.
Each short automation can call a script and pass it the desired temperature.
- alias: 'Scheduled Temperature 05:30'
    - platform: time
      at: '05:30:00'
    - condition: state
      below: 17.7
    - service: script.setpoint_temperature
        setpoint: 20
- alias: 'Scheduled Temperature 06:30'
    - platform: time
      at: '06:30:00'
    - condition: state
      below: 18.8
        setpoint: 22
The script sets the thermostat at the desired setpoint temperature:
#script:
  setpoint_temperature:
          temperature: '{{setpoint}}'
          hvac_mode: heat
EDIT
If you really want to consolidate it into a single automation, here’s one possible way to do it:
- alias: 'Scheduled Temperature'
    - platform: time
      at:
        - '05:30:00'
        - '06:30:00'
    choose:
      - conditions: "{{(trigger.now.time()|string)[:5] == '05:30' and states('sensor.temperature') < 17.7 }}"
              setpoint: 20
      - conditions: "{{(trigger.now.time()|string)[:5] == '06:30' and states('sensor.temperature') < 18.8 }}"
              setpoint: 22
If you don’t like this:
you can replace it with:
trigger.now.hour == 5 and trigger.now.minute == 30
Sorry, I never see you comment.
Many thanks for your help.
A question:
what does means: string)[:5] ?
Thanks a lot ! I never see conditions in the action part !
It’s python’s slice notation. It’s extracting the first 5 characters from the string containing the time.
The time is presented like this:
21:45:00
and we only need the first five characters containing the hours and minutes.
They are part of choose. For more information about choose, refer to the documentation:
Choose a group of actions
