I’ve been away from HA for a while so I’m very rusty!
I’d also like to have the pushbullet notification message read either grey or green bin, based on which condition triggered it?
I canake it work using 2 separate automations, but feel like it can be achieved in 1?
Any help much appreciated
Also, you might as well have your message tell you which bin to take out.
- data_template:
message: >
Take the
{% if (state_attr('sensor.grey_bin', 'days')|int) == 1 %} GREY
{% else %} GREEN
{% endif %}
Bin out
title: Home Assistant
service: notify.pushbullet
Thanks, I figured the or condition out myself
I was using the GUI editor which isn’t as powerful as direct yaml I guess.
For the notification data template I’m getting an error:
can not read a block mapping entry; a multiline key may not be an implicit key at line 84, column 10:
Yeah I figured it was an indentation error… but I’m still failing
- data_template:
message: >
Take the
{% else %} GREEN
{% endif %}
Bin out
Service should be indented…and have the dash if you move it up there. Or just remove the dash because it’s only a single action.
- service: notify.pushbullet
data_template:
message: >
Take the
{% else %} GREEN
{% endif %}
Bin out
Two other ways to structure the template (using inline-if):
data_template:
message: >
{% set d = state_attr('sensor.grey_bin', 'days')|int %}
Take the {{ 'GREY' if d == 1 else 'GREEN' }} bin out
data_template:
message: "Take the {{ 'GREY' if (state_attr('sensor.grey_bin', 'days')|int) == 1 else 'GREEN' }} bin out"
Yeah ok, makes sense.
I currently have only 1 automations.yaml file.
At some point I’ll get round to splitting them out, but I’m doing a full reinstall of my system so just wanted to get it up and running.
