I am attempting to create an automation to notify me when a ZigBee sensor (via ZigBee2MQTT) has failed to send an update for more than some number of seconds.
This is what my automation’s configuration looks like:
and that shows the expected number of seconds, starting at (near) zero when an update is received and increasing until the next update.
I can sometimes get the automation to trigger once, but then nothing else happens until (maybe) after I change something in the configuration, but usually not even after that.
My configuration seems the same as what is explained here, so I think I have the syntax right.
I suspect this is why my automation is not triggering, as I am waiting for a notification that the entity has not changed value for X time, but the trigger would only be re-evaluated if the entity does change value.
I thought this had been changed with a recent update, but it seems to still work as it did previously. As to where it’s explained… AFAIK, it was never explicitly explained anywhere except in forums posts like the one you linked. I found it out through empirical testing.
You would be better off just using a Template trigger:
